Hello all, We have SMDK2450 development kit with 64MB RAM and 256MB NAND Flash. We are able to download the kernel and basic file system through memory. What we need is to Boot the system from NAND flash. Boot from NAND Flash is happening but root fs mounting from NAND is not going through. The kernel log is enclosed below: --------------------------------------------------------------------- SMDK2416 # nand read 0xc0108000 0x400000 0x20cbff NAND read: device 0 offset 0x400000, size 0x20cbff 2149375 bytes read: OK SMDK2416 # bootm 0xc0108000 Boot with zImage Starting kernel ... Uncompressing Linux... done, booting the kernel. Linux version 2.6.35-rc4 (qmax@Qmax-U910) (gcc version 4.2.2) #4 Thu Jan 20 16:41:58 IST 2011 CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177 CPU: VIVT data cache, VIVT instruction cache Machine: SMDK2416 Memory policy: ECC disabled, Data cache writeback CPU S3C2416/S3C2450 (id 0x32450003) S3C24XX Clocks, Copyright 2004 Simtec Electronics CPU: MPLL on 800.000 MHz, cpu 400.000 MHz, mem 133.333 MHz, pclk 66.666 MHz CPU: EPLL on 96.000 MHz, usb-bus 48.000 MHz Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: root=/dev/mtd:rootfs rootfstype=cramfs noinitrd init=/linuxrc console=ttySAC0,115200 mem=64M PID hash table entries: 256 (order: -2, 1024 bytes) Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 60488k/60488k available, 5048k reserved, 0K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xffc00000 - 0xffe00000 ( 2 MB) vmalloc : 0xc4800000 - 0xe0000000 ( 440 MB) lowmem : 0xc0000000 - 0xc4000000 ( 64 MB) modules : 0xbf000000 - 0xc0000000 ( 16 MB) .init : 0xc0108000 - 0xc0130000 ( 160 kB) .text : 0xc0130000 - 0xc04e6000 (3800 kB) .data : 0xc0504000 - 0xc052d700 ( 166 kB) Hierarchical RCU implementation. RCU-based detection of stalled CPUs is disabled. Verbose stalled-CPUs detection is disabled. NR_IRQS:99 irq: clearing subpending status 00000003 irq: clearing subpending status 00000002 Console: colour dummy device 80x30 console [ttySAC0] enabled Calibrating delay loop... 199.47 BogoMIPS (lpj=498688) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok NET: Registered protocol family 16 S3C Power Management, Copyright 2004 Simtec Electronics S3C2416: Initializing architecture S3C2416: IRQ Support S3C24XX DMA Driver, Copyright 2003-2006 Simtec Electronics DMA channel 0 at c4808000, irq 88 DMA channel 1 at c4808100, irq 89 DMA channel 2 at c4808200, irq 90 DMA channel 3 at c4808300, irq 91 DMA channel 4 at c4808400, irq 92 DMA channel 5 at c4808500, irq 93 s3c-adc s3c24xx-adc: attached adc driver bio: create slab <bio-0> at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb s3c-i2c s3c2410-i2c: slave address 0x10 s3c-i2c s3c2410-i2c: bus frequency set to 65 KHz s3c-i2c s3c2410-i2c: i2c-0: S3C I2C adapter Advanced Linux Sound Architecture Driver Version 1.0.23. NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. NetWinder Floating Point Emulator V0.97 (extended precision) JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. ROMFS MTD (C) 2007 Red Hat, Inc. msgmni has been set to 118 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) lp: driver loaded but no devices found ppdev: user-space parallel port driver Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440 s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440 s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440 brd: module loaded loop: module loaded usbcore: registered new interface driver ub Uniform Multi-Platform E-IDE driver ide-gd driver 1.18 ide-cd driver 5.00 S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c24xx-nand s3c2412-nand: Tacls=3, 22ns Twrph0=8 60ns, Twrph1=3 22ns s3c24xx-nand s3c2412-nand: System booted from NAND s3c24xx-nand s3c2412-nand: NAND soft ECC NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit) Scanning device for bad blocks Bad eraseblock 0 at 0x000000000000 Bad eraseblock 1 at 0x000000400000 Bad eraseblock 2 at 0x000000800000 Bad eraseblock 3 at 0x000000c00000 Bad eraseblock 24 at 0x000006000000 Bad eraseblock 25 at 0x000006400000 Bad eraseblock 26 at 0x000006800000 Creating 8 MTD partitions on "NAND 256MiB 3,3V 8-bit": 0x000000000000-0x000000004000 : "Boot Agent" mtd: partition "Boot Agent" doesn't end on an erase block -- force read-only 0x000000000000-0x000000200000 : "S3C2410 flash partition 1" mtd: partition "S3C2410 flash partition 1" doesn't end on an erase block -- force read-only 0x000000400000-0x000000800000 : "S3C2410 flash partition 2" 0x000000800000-0x000000a00000 : "S3C2410 flash partition 3" mtd: partition "S3C2410 flash partition 3" doesn't end on an erase block -- force read-only 0x000000a00000-0x000000e00000 : "S3C2410 flash partition 4" mtd: partition "S3C2410 flash partition 4" doesn't start on an erase block boundary -- force read-only 0x000000e00000-0x000001800000 : "S3C2410 flash partition 5" mtd: partition "S3C2410 flash partition 5" doesn't start on an erase block boundary -- force read-only 0x000001800000-0x000003000000 : "S3C2410 flash partition 6" 0x000003000000-0x000010000000 : "S3C2410 flash partition 7" dm9000 Ethernet Driver, V1.31 usbmon: debugfs is not available ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected usbcore: registered new interface driver libusual usbcore: registered new interface driver usbserial USB Serial support registered for generic usbcore: registered new interface driver usbserial_generic usbserial: USB Serial Driver core USB Serial support registered for FTDI USB Serial Device usbcore: registered new interface driver ftdi_sio ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver USB Serial support registered for pl2303 usbcore: registered new interface driver pl2303 pl2303: Prolific PL2303 USB to serial adaptor driver mice: PS/2 mouse device common for all mice S3C24XX RTC, (c) 2004,2006 Simtec Electronics S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled No device for DAI UDA134X No device for DAI s3c24xx-i2s ALSA device list: No soundcards found. TCP cubic registered NET: Registered protocol family 17 drivers/rtc/hctosys.c: unable to open rtc device (rtc0) Root-NFS: No NFS server available, giving up. VFS: Unable to mount root fs via NFS, trying floppy. VFS: Cannot open root device "mtd:rootfs" or unknown-block(2,0) Please append a correct "root=" boot option; here are the available partitions: 1f00 16 mtdblock0 (driver?) 1f01 2048 mtdblock1 (driver?) 1f02 4096 mtdblock2 (driver?) 1f03 2048 mtdblock3 (driver?) 1f04 4096 mtdblock4 (driver?) 1f05 10240 mtdblock5 (driver?) 1f06 24576 mtdblock6 (driver?) 1f07 212992 mtdblock7 (driver?) Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0) [<c0136368>] (unwind_backtrace+0x0/0xf0) from [<c0153f64>] (panic+0x54/0xe4) [<c0153f64>] (panic+0x54/0xe4) from [<c01090d0>] (mount_block_root+0x1c4/0x20c) [<c01090d0>] (mount_block_root+0x1c4/0x20c) from [<c0109380>] (prepare_namespace+0x164/0x1c8) [<c0109380>] (prepare_namespace+0x164/0x1c8) from [<c0108908>] (kernel_init+0x108/0x14c) [<c0108908>] (kernel_init+0x108/0x14c) from [<c0131e2c>] (kernel_thread_exit+0x0/0x8) We look forward for any help in resolving the issue. Thanks and regards Rajam QMax Systems
SMDK2450 - mounting rootfs from NAND Flash
http://www.linuxquestions.org/questions/linux-embedded-78/smdk2450-linux... says you are using u-boot. What are you using for a bootloader? u-boot needs a uImage not a zImage. With u-boot are you doing a <nand scrub> and a <nand createbbt> as per http://narnia.cs.ttu.edu/drupal/node/131 Or is it not required on this platform?
