Hi, I want to debug an user application for mini2440 using arm-elf-gdb using serial port. Is it possible? Can anyone tell me step by step how to do it? Thanks & regards
How to debug user application using arm-elf-gdb and serial port
Yes you can debug using the gdb on ARM remotes including mini2440. The following pdf should assist you in that goal. http://files.meetup.com/1590495/debugging-with-qemu.pdf or other step by step instructions are available by http://www.linux.com/archive/feature/121735 http://blog.flameeyes.eu/2008/12/17/remote-debugging-with-gdb-part-1-gentoo http://blog.flameeyes.eu/2010/02/20/remote-debugging-with-gdb-part-2-gdb Hope this assists. Cheers.
