Can't mount SD card. [root@FriendlyARM /]# mount -t ext3 /dev/mmcblk0 mnt/sd_card mount: mounting /dev/mmcblk0 on mnt/sd_card failed: Invalid argument No, there are no partitions on the card. Just an ext3 file system. [root@FriendlyARM /]# mount -t ext3 /dev/mmcblk0p1 /mnt/sd_card mount: mounting /dev/mmcblk0p1 on /mnt/sd_card failed: No such file or directory Card leaving and coming is recognized. [root@FriendlyARM /]# m�c0: card aaaa removed s3c-sdi s3c2440-sdi: powered down. eth0: link down s3c-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz). s3c-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). s3c-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). s3c-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz�. s3c-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). s3c-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). s3c-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). s3c-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz). s3c-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). s3c-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). mmc0: new SD card at address aaaa eth0: link up, 100Mbps, full-duplex, lpa 0x45E1 mmcblk0: mmc0:aaaa SD02G 1.84 GiB mmcblk0: p1 [root@FriendlyARM /]# uname -a Linux FriendlyARM 2.6.32.2-FriendlyARM #2 Fri Jan 14 16:18:16 PST 2011 armv4tl unknown Any suggestions? Thanks.
mounting sd card
I tried the same command you use but without -t option. it gives me a warning but it works fine for me [root@FriendlyARM /]# mount /dev/mmcblk0p1 /mnt/sd_card
Check "/proc/filesystems" if it lists the ext3 filesystem as supported. If not, re-build your kernel with ext3 support.
