Hi, Im using a board with a S3C2440 processor (not the mini2440) with an old GCC Version 3.4.1. Now id like to update the compiler, because some software wont compile with the old one. I downloaded the ARM-Linux GCC 4.3.2 from here (i think this should work..?) and cross compiled a simple hello world console application and transferd it to my taget. I used the follow command to compile the application (helloWorld.c): /usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-gcc -o helloWorld helloWorld.c -Wl,-rpath=/usr/newcompiler/lib/ -Wl,-dynamic-linker=/usr/newcompiler/lib/ld-linux.so.3 I used rpath and dynamic-linker to force the use of the new glib on my target. Then i copied the the lib directory from /usr/local/arm/4.3.2/arm-nonelinux-gnueabi/libc/armv4t/lib to my target into /usr/newcompiler/lib/ If i start the helloWorld app he finds the libraries, but aborts with a Segmentation Fault. What am i missing?
new gcc version on s3c2440 --> Segmentation fault
Did you check (for example via 'strace') what libraries your program is using at runtime? Can you build your program with debug information and run it with 'catchsegv' to get an idea where it crashes?
Hi. Thanks for your answer. it tried to use ldd to see what libraries are used: # ldd ./helloWorld ldd: exited with unknown exit code (139) looks like it aborts with Signal number 11. SIGSEGV. and strace gives : # strace ./helloWorld execve("./helloWorld", ["./helloWorld"], [/* 11 vars */]) = 0 mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|0x4000000, -1, 0) = 0 --- SIGSEGV (Segmentation fault) @ 0 (0) --- +++ killed by SIGSEGV +++ Segmentation fault
Hi May be you need -mcpu=arm920t compiler option? Seems arm-none-linux-gnueabi-gcc by default use armv5 otptions. Sergio
