Has anyone tried directfb on FriendlyARM? I've cross-compiled it, but I'm having a problem with memcpy(). It crashes with an illegal opcode. I've tried with asm_memcpy() and libc_memcpy(), but it continues to fail. Can anyone help me? Thanks, Carlos Castro
Directfb
Hello Carlos, in another forum, about mmap framebuffer problem, I read this: > You need to set the size of the fb1 framebuffer by writing it to > /sys/class/graphics/fb1/size, like this (for a 4MB framebuffer): > echo 4194304 > /sys/class/graphics/fb1/size can be the same problem? Please let me know about: I'm trying the DirectFB too. Clemente.
Hi Clemente, thanks for replying. I don't have that file. This is what I have in that directory: [root@FriendlyARM /]# cd /sys/class/graphics/fb0/ [root@FriendlyARM fb0]# ls bits_per_pixel dev name stride blank device pan subsystem console mode rotate uevent cursor modes state virtual_size [root@FriendlyARM fb0]# But I don't think that the problem is with the fbdev, cause SDL is working fine, and even fb-gnash, that is a flash player using directfb is working properly. Only the test apps from directfb don't work ( like dfbinfo). When I try one of them it gives me this error: [root@FriendlyARM fb0]# dfbinfo ~~~~~~~~~~~~~~~~~~~~~~~~~~| DirectFB 1.4.3 |~~~~~~~~~~~~~~~~~~~~~~~~~~ (c) 2001-2009 The world wide DirectFB Open Source Community (c) 2000-2004 Convergence (integrated media) GmbH ---------------------------------------------------------------- (*) DirectFB/Core: Single Application Core. (2009-12-09 10:17) [ DEBUG ][ TRACE ] (*) Direct/Memcpy: Forced to use libc memcpy() (!) [ 569: 0.000] --> Caught signal 4 (at 0x4011ac78, illegal opcode) <-- sh: nm: not found (-) [ 569: -STACK- ] #0 0x4013eb84 in signal_handler () from /usr/local/arm/4.3.2/lib/libdirect-1.4.so.0 [0x40130000] #1 0x4011ac1c in fusion_arena_enter () from /usr/local/arm/4.3.2/lib/libfusion-1.4.so.0 [0x40118000] #2 0x4009d368 in dfb_core_create () from /usr/local/arm/4.3.2/lib/libdirectfb-1.4.so.0 [0x40026000] #3 0x00008640 in DirectFBCreate () from dfbinfo [0x8000] Segmentation fault [root@FriendlyARM fb0]# I hope we can help each other. Carlos
Hello Carlos, I have this problem, but with a different version of directfb: root@mini2440:~# dfbinfo ~~~~~~~~~~~~~~~~~~~~~~~~~~| DirectFB 1.2.7 |~~~~~~~~~~~~~~~~~~~~~~~~~~ (c) 2001-2008 The world wide DirectFB Open Source Community (c) 2000-2004 Convergence (integrated media) GmbH ---------------------------------------------------------------- (*) DirectFB/Core: Single Application Core. (2009-12-13 09:34) (*) Direct/Thread: Started 'VT Switcher' (-1) [CRITICAL OTHER/OTHER 0/0] <8388608>... (*) Direct/Thread: Started 'Keyboard Input' (-1) [INPUT OTHER/OTHER 0/0] <8388608>... (*) DirectFB/Input: Keyboard 0.9 (directfb.org) (!) [ 2187: 0.000] --> Caught signal 11 (sent by the kernel) <-- (!) DirectFB/core/vt: Unable to disallocate VT! --> Device or resource busy Aborted I'm trying to find a solution serching the web. Clemente.
app # ./df_andi =======================| DirectFB 1.0.1 |======================= (c) 2001-2007 The DirectFB Organization (directfb.org) (c) 2000-2004 Convergence (integrated media) GmbH ------------------------------------------------------------ (*) DirectFB/Core: Single Application Core. (2009-05-07 01:56) (*) Direct/Thread: Running 'VT Switcher' (CRITICAL, 1155)... (!) Direct/Modules: Unable to dlopen `/lib/directfb-1.0-0/inputdrivers/libdirectfb_tslib.so'! --> libts-0.0.so.0: cannot open shared object file: No such file or directory (*) Direct/Thread: Running 'PS/2 Input' (INPUT, 1156)... (*) DirectFB/Input: IMPS/2 Mouse 1.0 (directfb.org) (*) Direct/Thread: Running 'Linux Input' (INPUT, 1157)... (*) DirectFB/Input: s3c-keypad (1) 0.1 (directfb.org) (*) Direct/Thread: Running 'Linux Input' (INPUT, 1158)... (*) DirectFB/Input: S5P TouchScreen (2) 0.1 (directfb.org) (*) Direct/Thread: Running 'Keyboard Input' (INPUT, 1159)... (*) DirectFB/Input: Keyboard 0.9 (directfb.org) (!) Direct/Modules: Could not open module directory `/lib/directfb-1.0-0/gfxdrivers'! --> No such file or directory (*) DirectFB/Graphics: Generic Software Rasterizer 0.6 (directfb.org) (*) DirectFB/Core/WM: Default 0.3 (directfb.org) DirectFB: Error opening lcd DIRECTFB: LCD_IOCTL ioctl call failed df_andi.c <497>: [Application exited without deinitialization of DirectFB!] *** [core.c:813 in dfb_core_deinit_check()] (!!!) *** WARNING [still objects in 'Layer Region Pool'] *** [object.c:231 in fusion_object_pool_destroy()] (!!!) *** WARNING [still objects in 'Layets in 'Surface Pool'] *** [object.c:231 in fusion_object_pool_destroy()] /app # ./df_andi ./df_andi: error while loading shared libraries: libdirectfb-1.0.so.0: cannot open shared object file: No such file or directory /app # msh: can't execute 'strace': No such file or directory /app # ./df_fire =======================| DirectFB 1.0.1 |======================= (c) 2001-2007 The DirectFB Organization (directfb.org) (c) 2000-2004 Convergence (integrated media) GmbH ------------------------------------------------------------ (*) DirectFB/Core: Single Application Core. (2009-05-07 01:56) (*) Direct/Thread: Running 'VT Switcher' (CRITICAL, 1158)... (!) Direct/Modules: Unable to dlopen `/lib/directfb-1.0-0/inputdrivers/libdirectfb_tslib.so'! --> libts-0.0.so.0: cannot open shared object file: No such file or directory (*) Direct/Thread: Running 'PS/2 Input' (INPUT, 1159)... (*) DirectFB/Input: IMPS/2 Mouse 1.0 (directfb.org) (*) Direct/Thread: Running 'Linus3cfb s3cfb: invalid bits per pixel s3cfb s3cfb: invalid bits per pixel x Input' (INPUT, 1160)... (*) DirectFB/Input: s3c-keypad (1) 0.1 (directfb.org) (*) Direct/Thread: Running 'Linux Input' (INPUT, 1161)... (*) DirectFB/Input: S5P TouchScreen (2) 0.1 (directfb.org) (*) Direct/Thread: Running 'Keyboard Input' (INPUT, 1162)... (*) DirectFB/Input: Keyboard 0.9 (directfb.org) (!) Direct/Modules: Could not open module directory `/lib/directfb-1.0-0/gfxdrivers'! --> No such file or directory (*) DirectFB/Graphics: Generic Software Rasterizer 0.6 (directfb.org) (*) DirectFB/Core/WM: Default 0.3 (directfb.org) (#) DirectFBError [IDirectFB::CreateSurface() failed]: Not supported! /app # ./df_andi =======================| DirectFB 1.0.1 |======================= (c)2001-2007 The DirectFB Organization (directfb.org) (c) 2000-2004 Convergence (integrated media) GmbH ------------------------------------------------------------ (*) DirectFB/Core: Single Application Core. (2009-05-07 01:56) (*) Direct/Thread: Running 'VT Switcher' (CRITICAL, 1168)... (!) Direct/Modules: Unable to dlopen `/lib/directfb-1.0-0/inputdrivers/libdirectfb_tslib.so'! --> libts-0.0.so.0: cannot open shared object file: No such file or directory (*) Direct/Thread: Running 'PS/2 Input' (INPUT, 1169)... (*) DirectFB/Input: IMPS/2 Mouse 1.0 (directfb.org) (*) Direct/Thread: Running 'Linux Input' (INPUT, 1170)... (*) DirectFB/Input: s3c-keypad (1) 0.1 (directfb.org) (*) Direct/Thread: Running 'Linux Input' (INPUT, 1171)... (*) DirectFB/Input: S5P TouchScreen (2) 0.1 (directfb.org) (*) Direct/Thread: Running 'Keyboard Input' (INPUT, 1172)... (*) DirectFB/Input: Keyboard 0.ectory (*) DirectFB/Graphics: Generic Software Rasterizer 0.6 (directfb.org) (*) DirectFB/Core/WM: Default 0.3 (directfb.org) DirectFB: Error opening lcd DIRECTFB: LCD_IOCTL ioctl call failed df_andi.c <497>: (#) DirectFBError [dfb->CreateFont( dfb, FONT, &desc, &font )]: File not found! (!!!) *** WARNING [Application exited without deinitialization of DirectFB!] *** [core.c:813 in dfb_core_deinit_check()] (!!!) *** WARNING [still objects in 'Layer Region Pool'] *** [object.c:231 in fusion_object_pool_destroy()] (!!!) *** WARNING [still objects in 'Layer Context Pool'] *** [object.c:231 in fusion_object_pool_destroy()] (!!!) *** WARNING [still objects in 'Surface Pool'] *** [object.c:231 in fusion_object_pool_destroy()]
