Download link ======================== 1. User manual(Chinese) http://arm9download.cncncn.com/mini6410/mini6410um-20101121.zip ======= Linux ======= 1. U-boot: http://arm9download.cncncn.com/mini6410/linux/20101121/u-boot-mini6410-2... 2. Linux-2.6.36 source code tarball http://arm9download.cncncn.com/mini6410/linux/20101121/linux-2.6.36-2010... 3. arm-linux-gcc-4.5.1: default Armv6, support vfp http://arm9download.cncncn.com/mini6410/linux/20101121/arm-linux-gcc-4.5... 4. arm-qtopia-2.2.0 source code tarball with build script http://arm9download.cncncn.com/mini6410/linux/20101121/arm-qtopia-201011... 5. arm-qte-4.7.0 source code with build script http://arm9download.cncncn.com/mini6410/linux/20101121/arm-qte-4.7.0-201... 6. arm-qte-extended-4.4.3 source code tarball with build script http://arm9download.cncncn.com/mini6410/linux/20101121/arm-qt-extended-4... 7. busybox-1.17.2 source code tsrball with fa.config http://arm9download.cncncn.com/mini6410/linux/20101121/busybox-1.17.2-20... 8. examples: i2c, camera, pwn, buttons, led, math etc. http://arm9download.cncncn.com/mini6410/linux/20101121/examples-mini6410... 9. rootfs-qtopia-qt4 tarball http://arm9download.cncncn.com/mini6410/linux/20101121/rootfs_qtopia_qt4... ======= Android 2.1 ======= 1. Linux-2.6.28.6 source code tsrball http://arm9download.cncncn.com/mini6410/android/20101121/android-kernel-... 2. Android 2.1 tarball http://arm9download.cncncn.com/mini6410/android/20101121/android-2.1-fs-... 3. Android 2.1 rootfs tarball http://arm9download.cncncn.com/mini6410/android/20101121/rootfs_android-... ======= WindowsCE 6 ======= 1. Windowsce6 BSP http://arm9download.cncncn.com/mini6410/wince6/20101121/Mini6410-WinCE6-... 2. SDK for VS2005 http://arm9download.cncncn.com/mini6410/wince6/20101121/Mini6410-SDK.zip ======= Images======= 1. Linux images http://arm9download.cncncn.com/mini6410/mini6410-linux-images-20101121.zip 2. Android 2.1images http://arm9download.cncncn.com/mini6410/mini6410-android-images-20101129... 3. WindowsCE images http://arm9download.cncncn.com/mini6410/mini6410-wince-images-20101121.zip 4. Ubuntu images http://arm9download.cncncn.com/mini6410/mini6410-ubuntu-images-20101121.zip
Mini6410 update(2010-11-21)
It's a shame, but i understand... I am interested by the 1wire under Windows CE, i will have to write my own driver... Thanks Domodom
I have the LCD TOUCH SCREEN 4.3 and need to use the RCA output at 1024 x 768 resolution. How do I? Do you have a source code example?
The touch screen library, tslib has been extended to include support for the mini6410. Do you have the source to create the module_raw friendlyarm-ts-input.so, it should just be one source file from plugins directory, without this it is not possible to compile any code against the tslib which uses this module or get the touchscreen working
Mindee, three questions: 1) What is the maximum resolution of the output TV OUT? How do I get it to be used in a data show and a great display resolution? Can I have 1024 X 768 TV OUT? How? 2) What is the example source program that allows me to ON and OFF the LCD TOUCH. Like a toggle. Do you have a source example? 3) What is your direct email, msn or skype?
Mindee, one more question: 1) The system is installed WINDOWS CE in chinese. What is the link of the version in English?
Hi i compiled the kernel 2.6.32 and i flashed with new rootfs-qtopia-qt4 file system but the mouse doesn't work and there is no SMplayer has any had this problem. i din use the images from above link as speed is very slow. And its not running from SD card as well.
Have a look on the ftp server: http://www.friendlyarm.net/downloads#download
