Hi friends, I'm following this tutorial to install Qtopia for linux PC Host. (http://intresting2440.blogspot.com/2010/07/install-arm-qtopia-2202010010...). I did all these steps, but when I'll run bild, I got this error: root@ubuntu:/opt/FriendlyARM/mini2440/arm-qtopia# ./build-all ./build: line 7: ./configure: No such file or directory make: *** No targets specified and no makefile found. Stop. ./build-konq: line 7: /opt/FriendlyARM/mini2440/arm-qtopia/qtopia-2.2.0-FriendlyARM/setQpeEnv: No such file or directory configure: WARNING: If you wanted to set the --build type, don't use --host. If a cross compiler is detected then cross compile mode will be used. Do you have some tips to help me to fix this? If I install QT-Designer I don't need to do this? Thanks! Rodolfo
Install arm-qtopia-2.2.0_20100108 error
Ok here i post my exact Problem if i want to build the example hello: seven@seven:~/opt/FriendlyARM/mini2440/arm-qtopia/hello$ ./build ./build: Zeile 3: /opt/FriendlyARM/mini2440/arm-qtopia/qtopia-2.2.0-FriendlyARM/setQpeEnv: Datei oder Verzeichnis nicht gefunden ./build: Zeile 4: qmake: Kommando nicht gefunden. make: *** Keine Regel, um »clean« zu erstellen. Schluss. make: *** Keine Targets angegeben und keine »make«-Steuerdatei gefunden. Schluss.
Maybe here: http://www.friendlyarm.net/downloads#download They use to be on the Downloads page, so if they are not on the download server I don'[t where else to look.
You'll find it on the Mini2440 DVD. If you don't have one you can download the DVD iso from FriendlyArm's FTP.
