DNS on mini2440
Davi
Hi, somebody already change any parameter of boa server or other file on
linux to resolv names?
I change my resolve.conf writting on it the directive 'search' with the
name of my server. I edit also the boa.conf with 'ServerName' parameter.
All tries were unsuccessfully.
AndreT
configured in /etc/resolv.conf using the following format
nameserver xxx.xxx.xxx.xxx
you can add multiple dns addresses by repeating the line any number of
times.
Davi
Sorry, i didn't mention that my resolv.conf already is like u sad.
I add the line with 'search' command, and the line with nameserver already
was configured.
But thanks i will keep trying.
AndreT
Is the DNS server reachable from the mini?
When you configured an IP address did you use correct subnet mask and
specify a valid default gateway?
Davi
Yes, yes, all network parameters were configured.
I already have progress, i'm trying improve my results. I ll try to
register the mini on dns server, i presume that this way works.
But i would like a better solution, for example, just typing the name of
mini on browser and access it. Maybe configure the client machine also
helps.
Any idea is welcome.
sushant
how to change DNS in MINI2440
Juergen
Can you elaborate more details? Your question makes no sense without a
little bit more context.
Think this was answered recently ... in the last few weeks.
in /etc/resolv.conf
nameserver 192.168.1.1
specifically the DNS you want to use
Also Juergen said there was another step, see if you can find it.
http://www.friendlyarm.net/forum/topic/5894
Or, have I got this wrong again :)
