C? C++? QT? Python? Java?
rob
Hello to everyone! I have a mini6410 and I want to start developing apps. I
managed to install python because I have a good experience with this
language, but I have read that many people are programming in QT? Why I
should use QT and not python, java or C++??
I really want to use Python ,what do you think??
Thanks very much!!
Dezso
Lucky you, I cant get my head around any of those, only understand VS C#,
and they are suck.
urnausjr
Programming in C and/or C++ is certainly recommended on embedded systems
because of the hardware limitations. As an interpreted language, Python is
not as efficient as compiled languages such as C and C++. Qt (with C++) is
the base of the default desktop environment (Qtopia) on mini6410, therefore
is the framework most used by people programming on it. C is also fine, as
the underlying system is based on Linux, which is developed with C.
Installing Windows CE and Android is easy with FriendlyARM devices, so of
course C# and Java can be used, only that they are less popular.
If you're just starting to learn to program on embedded devices, and hope
to use mini6410 to do so, I would recommend C, C++ and Qt because Linux is
the most used in embedded systems, and also Qt is a cross-platform
framework (on Linux, Mac OS X, and Windows). The Java-Android combination
will probably be more and more popular in the future, but if you're trying
to learn Android programming, mini6410 is not a good choice because the
support is still a bit lacking...
ellion88
Hello rob,
If you want to get an idea of performance between C and Python, you can
visit this site:
http://shootout.alioth.debian.org/
urnausjr is right, C and C + + languages are best suited to develop in the
embedded world.
Best regards,
mabada
Hi! I have mini 6410 too. but I don't know how to write a program on it and
run . Which compiler we use for it. I couldn't understand that . pleaseee
help meee:(
Sanath
i like to use C language to program S3C2440A processor, but where can i
find C header file for this processor?
