Hello, I have bought a mini2440 with a 3.5" touchscreen, now this new one seems to have a different touchscreen compared to the previous ones. On the back of it it says LCDX35 instead of LCDT35 that has been on my previous ones with the Toppoly display. Is here anyone with the new display? I can't get it to work with the Buserror's kernel, does anyone have any ideas? Now it only shows some lines, what do I need to do? According to http://www.thaieasyelec.com/Development-Tools/Development-Board/Embedded... it is made by Sony and has been available since 18.10.
New Sony LCDX35 LCD, linux support?
Hi, zes it seems there is new type of display. We need to add it to kernel to work properly. Anyway there's statement:3.5 inch screen switch to (X35, SONY) Driver is now available on DVD. So possibility would be to ask for driver or get DVD. cheers, marek
Buserrors kernel doesn't seem to have the support for X35 yet, but I found a config_mini2440_x35 in the latest kernel source (20100921) on http://www.arm9.net/download.asp, maybe that could work? I uploaded the file here for a bit faster download, if anyone needs: http://www.filefactory.com/file/b44h06b/n/linux-2.6.32.2-mini2440-201009... Here is also a datasheet for it: http://arm9download.cncncn.com/datasheet/ACX502BMU.pdf Would it be possible to use the settings/driver from the friendlyarm (arm9.net) kernel in the buserrors kernel? Are some driver files required or only the settings from the config_mini2440_x35 file?
I'll try to add values from friendlyarm kernel to buseror but I'm confused.
There is different setup for FA kernel and buserror kernel (also values are
different). Anybody experienced here?
FA T35 kernel:
#define LCD_WIDTH 240
#define LCD_HEIGHT 320
#define LCD_PIXCLOCK 170000
#define LCD_RIGHT_MARGIN 25
#define LCD_LEFT_MARGIN 0
#define LCD_HSYNC_LEN 4
#define LCD_UPPER_MARGIN 1
#define LCD_LOWER_MARGIN 4
#define LCD_VSYNC_LEN 1
FA X35 kernel:
#define LCD_UPPER_MARGIN 0
#define LCD_VSYNC_LEN 9
buseror kernel t35 (some values):
_xres=240
margin_left=21
margin_right=25
hsync=6
_yres=230
margin_top=2
margin_bottom=4
vsync=2
I can't assume values for X35 ;). Anyway you can try compile FA x35
defconfig and load it if it display correctly.
good luck,
marek
Does your LCD have a X35 printed on the top right hand corner on the front of the display? If it does, it will explain some of the problems I am experiencing! :)
Hello, No it's on the back of the display, on the circuit board. With the T35 kernel I see only some colored lines on the X35 display. I think I will try to change the hsync and vsync values in the buserror kernel, and if it doensn't help I probably need to change to the FA kernel.
Hi, I have the same problem! In my lcd there is a "x35" printed on the top right. Anyone found any solution? I can't compile the kernel because does not have the configuration file for this lcd model.. Into the DVD there is an zImage for x35 that work's, so someone has this configuration file. Referent lcd configuration look at this link: http://osdir.com/ml/handhelds.linux.kernel/2004-08/msg00063.html O mais estranho é que o kernel dos outros dispositivos não chega nem a ser gravado na memoria do kit. "Erasing... Fail..."
Sorry for the last sentence... [The strange thing is that the kernel of the other devices is not even being recorded in the kit memory. "Erasing ... Fail ..."]
Try compiling this kernel: http://rapidshare.com/files/431859567/linux-2.6.32.2-mini2440-20100921.t... It came on the dvd with my mini2440
I compiled the kernel from Friendlyarm (from linux-2.6.32.2-mini2440-20100921.tar.gz), and at least the kernel logo is displayed correctly. But the FriendlyArm-kernel doesn't seem to work with SD-cards in the same way as Buserror's kernel, so I can't get it to load the filesystem from the same SD card as where the kernel uImage is... So I think it would be easier to try to edit the config file from buserrors kernel, if anyone knows how the LCD hsync and vsync and other parameters should be set, please share. In buserrors kernel, the "mini2440=4tb" option gives me some picture, but the picture is too bright, and the resolution is wrong (640x480).
AndreT successfully test X35 display on 2.6.37-rc3 kernel today. Add lines to arch/arm/mach-s3c2440/mach-mini2440.c This source is from AndreT: http://pastebin.com/ZZCVxF9x (thanks).
Hi, I successfully compile the kernel linux-2.6.32.2-mini2440-20100921.tar.gz to x35 LCD. Now I would like to know if there is a max size of zImage. I've compiled this kernel with the original configuration, but when I added more support into the kernel (bluetooth and wireless drivers for example) and his size increases of 2,16Mbytes for 2,38Mbytes, I can't write the zImage into the mini2440. Someone know why? "Erasing.... fail..." My flash memory have 256Mbytes.
Hello everyone, I built the kernel for android running on micro2440 kit with the new X35 LCD. I modified the mach-mini2440.c as AndreT did but I couldn't get working the backlight; Could anybody can tell me what should I do? Thanks all!
Hello Andret, What parameters do you mention?I follows this guide ://mymicro2440.wordpress.com/2010/11/10/boot-android-from-sd-card/ and modified the display parameters in the file mach-mini2440.c (android-kernel_20090825.tgz) as you did here. It seem that the file mach-mini2440.c is modified to support only for X35 display in this kernel, others are removed. But thebacklight does not work. Khang.
What kernel_params are you passing in u-boot? There should be something like: mini2440=3tb (3=display type, t=touchscreen, b=backlight). marek
Hello open-nandra, The params that I passed to the kernel are: setenv bootcmd mmcinit \; ext2load mmc 0:2 0×31000000 uImage \; bootm 0×31000000 setenv bootargs root=/dev/mmcblk0p3 rootfstype=ext3 mini2440=xtb rootdelay=3 init=/linuxrc with xtb = 1tb, 2tb, 3tb, ... It has not effect on the display because the support of other display has been removed from mach-mini2440.c file except for X35. Thanks!
I have got a new mini2440 board on which it has a mark x35 on top right corner. How to port android for this board, please give any links for download of kernel and tool to cross compile the kernel..
Hi. Here is zImage for Android which is used to port into mini2440 X35 screen. Get it and try to install into your X35 board and tell me the result. Because I have T35 type so that I could not try it by myself. Link to download http://www.mediafire.com/?d4f45usa5x0k9b5 Good luck.
Hello whitebank, I have tried your image available at : http://www.mediafire.com/?d4f45usa5x0k9b5.It works on my mini2440 with X35 display. Thanks a lot. But now I am trying to modify the kernel source android-kernel_20090825.tgz to add support for X35. I have made following changes in the source code : Added in the file <source code>/driver/video/Kconfig config FB_S3C2410_X240320 boolean "3.5 inch 240X320 LCD(ACX502BMU)" depends on FB_S3C2410 help 3.5 inch 240X320 LCD(ACX502BMU) Also in the file mach-mini2400.c ....... ....... #elif defined(CONFIG_FB_S3C2410_X240320) #define LCD_WIDTH 240 #define LCD_HEIGHT 320 #define LCD_PIXCLOCK 170000 #define LCD_RIGHT_MARGIN 25 #define LCD_LEFT_MARGIN 0 #define LCD_HSYNC_LEN 4 #define LCD_UPPER_MARGIN 0 #define LCD_LOWER_MARGIN 4 #define LCD_VSYNC_LEN 9 #define LCD_CON5 (S3C2410_LCDCON5_FRM565 | S3C2410_LCDCON5_INVVDEN | S3C2410_LCDCON5_INVVFRAME | S3C2410_LCDCON5_INVVLINE | S3C2410_LCDCON5_INVVCLK | S3C2410_LCDCON5_HWSWP ) After this I have rebuilt the kernel. Although I am able to boot the board with this newly built image, but there is no display on the X35 screen. The board works find with Android when I am using the zImage that you have built for X35. Can you please tell me if I am missing something here? Thanks and Regards, Souvik
Solved the issue. Ported mini2440_backlight.c driver code to Android kernel. Now I am able to see the display. Regards, Souvik
hey Souvik, is ur kernel working well with the touchscreen and display x35? I'm having problems with the touchscreen.
hi all
i hav sony 3.5" x-35 lcd with friendly arm board .but it need
some power on delay to display. but lcd T-35 is working fine with my
hardware . so please let me know it is hardware problem or software
problem.
Hi, I have mini2440 with 3.5" LCD X35. But I can't find WinCE 5.0 image English version. Who has these image, share it please. Thanks
