serial port kernel config
japie
This is probably a stupid question but what kernel driver do I have to
activate to get a "standard" serial port?
I have a mini2440-7", installed u-boot and a fresh buildroot system with
kernel 2.6.32.2 on sd-card and it is al running like a charm expect for
owfs, I am trying to access my serial 1-wire adapter but keep running into
trouble.
There are 3 serial devices /dev/s3c2410_serial0-2 but owfs has trouble
while setting the baudrate, do I need any other driver besides s3c2410?
open-nandra
Hi, there should be device /dev/ttySAC0-SAC2 for serial port.
japie
ttySAC* is not created, I use kernel dynamic device creation did I mis some
hardware config why there not created? (if the device is there the /dev
entry would be created right?)
open-nandra
Right. How do you dynamically create devices. With mdev?
japie
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
But running "mdev -s" manually didn't add them, devtmpfs normally takes
care of things quite well, do I miss a driver:
Linux version 2.6.32.2-FriendlyARM (root@ubuntu) (gcc version 4.4.4
(Buildroot 0
CPU: VIVT data cache, VIVT instruction cache
Machine: FriendlyARM Mini2440 development board
CPU S3C2440A (id 0x32440001)
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: console=ttySAC0,115200 mini2440=1tb rootfstype=ext4
root=/t
PID hash table entries: 256 (order: -2, 1024 bytes)
Memory: 64MB = 64MB total
Memory: 62352KB available (2144K code, 293K data, 80K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:85
irq: clearing pending status 02000000
console [ttySAC0] enabled
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
bio: create slab <bio-0> at 0
SCSI subsystem initialized
s3c-i2c s3c2440-i2c: slave address 0x10
s3c-i2c s3c2440-i2c: bus frequency set to 98 KHz
s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
msgmni has been set to 121
alg: No test for stdrng (krng)
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered (default)
Console: switching to colour frame buffer device 100x30
leds    initialized
Hello, Mini2440 module is installed !
buttons initialized
pwm     initialized
adc     initialized
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
loop: module loaded
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: S3C24XX OHCI
usb usb1: Manufacturer: Linux 2.6.32.2-FriendlyARM ohci_hcd
usb usb1: SerialNumber: s3c24xx
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver ums-sddr09
usbcore: registered new interface driver ums-sddr55
mice: PS/2 mouse device common for all mice
s3c2410 TouchScreen successfully loaded
input: s3c2410 TouchScreen as /devices/virtual/input/input0
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
i2c /dev entries driver
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
s3c-sdi s3c2440-sdi: powered down.
s3c-sdi s3c2440-sdi: mmc0 - using pio, hw SDIO IRQ
s3c-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz).
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
s3c2410-rtc s3c2410-rtc: setting system clock to 2018-04-28 12:42:43 UTC
(15249)
s3c-sdi s3c2440-sdi: running at 398kHz (requested: 400kHz).
Waiting for root device /dev/mmcblk0p3...
s3c-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz).
mmc0: new SD card at address 0002
mmcblk0: mmc0:0002 SN02G 1.87 GiB
 mmcblk0: p1 p2 p3 p4
usb 1-1: new full speed USB device using s3c2410-ohci and address 2
EXT4-fs (mmcblk0p3): warning: maximal mount count reached, running e2fsck
is red
EXT4-fs (mmcblk0p3): recovery complete
EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode
VFS: Mounted root (ext4 filesystem) on device 179:3.
Freeing init memory: 80K
usb 1-1: New USB device found, idVendor=058f, idProduct=9254
usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1: Product: Generic USB Hub
usb 1-1: Manufacturer: ALCOR
usb 1-1: configuration #1 chosen from 1 choice
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
Adding 265032k swap on /dev/mmcblk0p1.  Priority:-1 extents:1
across:265032k SS
japie
If I understand correctly the naming scheme was altered so s3c2410_serial
should have be the same.
setserial is showing me /dev/s3c2410_serial1, UART: undefined, Port:
0x0000, IRQ: 73
Is this excepted behavior?
sanaaa
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x29000000 (irq = 16) is a
S3C2440/10
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x29004000 (irq = 20) is a
S3C2440/10
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x29008000 (irq = 24) is a
S3C2440/10
loop: module loaded
but when i connect GPS at serial1 it says you donot have permisiion to read
/write? can any one help me here ??
