hi all what is problem "./test_capture: line 1: syntax error: "(" unexpected"? [root@FriendlyARM /]# cd sdcard [root@FriendlyARM /sdcard]# ls mjpg-streamer s3c2440camera.ko test_capture [root@FriendlyARM /sdcard]# chmod u+x s3c2440camera.ko [root@FriendlyARM /sdcard]# chmod u+x test_capture [root@FriendlyARM /sdcard]# insmod s3c2440camera.ko [root@FriendlyARM /sdcard]# ./test_capture ./test_capture: line 1: syntax error: "(" unexpected [root@FriendlyARM /sdcard]# regards
masjid line 1: syntax error: "(" unexpected is solved just cross compile your code using arm-linux-gcc. I mean use cross complier
suppose your crosscompiling or linking didn't work at all. I got exacly the same error message when my lazarus/fpc cross arm compiler was not set up correctly (and produced some kind of error file or wrong type of linker file) This file is what your target tries to execute(or at least display)
Im working with arm DM3730 in that i wrote a shell script for testing gpio by led .... i got the same error /bin/led.sh: line 3: syntax error: "(" unexpected #!/bin/sh GPIO_min=( 70 88 140 116 55 17 12 158 161 ) GPIO_max=( 85 91 143 119 58 20 13 159 162 ) for ((i=0; i < 9; i++)); do for ((j=${GPIO_min[i]}; j < ${GPIO_max[i]}; j++)); do echo $j > /sys/class/gpio/export sleep .5 echo out > /sys/class/gpio/gpio$j/direction sleep .5 echo 1 > /sys/class/gpio/gpio$j/value sleep .5 echo 0 > /sys/class/gpio/gpio$j/value sleep .5 echo 1 > /sys/class/gpio/gpio$j/value sleep .5 done done ~ ~
