Hi, I am writing some C code for the MINI2440 board and I am facing an issue: I am trying to configure the interrupt handlers (I am using the pre-installed bootloader to test my firmware). It seems that I cannot modify the data in the physical addresses of the interrupt (0x00000000/0x00000004/0x00000008/etc) because those are addresses of the NOR/NAND. After the boot is compled, is there any way to remap the SDRAM at 0x00000000? Does anybody know how/where to install those interrupt handlers? Are there some pre-defined addresses where to install them and where the bootloader is setting the interrupt vectors? Thanks in advance for your help, Damiano
