Hey! I am trying to build my first root file system for my mini2440-64MB board. It is giving me a headache for past few days. Here is what I've done so far 1. Compiled kernel 2.6.32.2 using arm-linux-gcc 4.3.2 (and also 4.4.1) It seems all goes well. 2. after compiling rootFS I get this structure bin linuxrc -> bin/busybox sbin usr execute chmod command on bin/busybox run mkyaffs2image --> gives me myrootfs.img in DNW select option [y] and transfer myrootfs.img then select [b] to boot the system. linux_cmd_line parameter is set to: "noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0" Here is what I get (no changes made): -------------------------------------------------------------- s3c2410-rtc s3c2410-rtc: setting system clock to 2006-04-03 19:46:09 UTC (1144093569) yaffs: dev is 32505859 name is "mtdblock3" yaffs: passed flags "" yaffs: Attempting MTD mount on 31.3, "mtdblock3" yaffs_read_super: isCheckpointed 0 VFS: Mounted root (yaffs filesystem) on device 31:3. Freeing init memory: 156K Warning: unable to open an initial console. request_module: runaway loop modprobe binfmt-464c request_module: runaway loop modprobe binfmt-464c request_module: runaway loop modprobe binfmt-464c request_module: runaway loop modprobe binfmt-464c request_module: runaway loop modprobe binfmt-464c -------------------------------------------------------------- If I execute make CROSS_COMPILE=arm-linux- ARCH=arm I get the following error: -------------------------------------------- s3c2410-rtc s3c2410-rtc: setting system clock to 2006-04-03 19:27:42 UTC (1144092462) yaffs: dev is 32505859 name is "mtdblock3" yaffs: passed flags "" yaffs: Attempting MTD mount on 31.3, "mtdblock3" yaffs_read_super: isCheckpointed 0 VFS: Mounted root (yaffs filesystem) on device 31:3. Freeing init memory: 156K Warning: unable to open an initial console. Failed to execute /linuxrc. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. Backtrace: [<c00341cc>] (dump_backtrace+0x0/0x10c) from [<c03297d0>] (dump_stack+0x18/0x1c) r7:00000000 r6:00000000 r5:c001f180 r4:c0481b10 [<c03297b8>] (dump_stack+0x0/0x1c) from [<c0329820>] (panic+0x4c/0x114) [<c03297d4>] (panic+0x0/0x114) from [<c002f598>] (init_post+0xa8/0x10c) r3:00000000 r2:c394d000 r1:c394d100 r0:c03dae0c [<c002f4f0>] (init_post+0x0/0x10c) from [<c00084b4>] (kernel_init+0xe4/0x114) r5:c001f180 r4:c04812a0 [<c00083d0>] (kernel_init+0x0/0x114) from [<c004bbbc>] (do_exit+0x0/0x620) r5:00000000 r4:00000000 -------------------------------------------- I tried to extract root_qtopia from DVD and run mkyaffs2image on the extracted folder --> again I got myrootfs.img BUT THIS ONE WORKS FINE !!! So I asume my kernel is OK. There are a lot of tutorials online showing how to build rootfs. I am pretty sure I've followed all of them (not all, but you know what I mean). I even put some answers from china forums throug google translation system. However. No matter what I do, I could not make my rootfs to boot. Any suggestions, links, tricks,... are very appreciated. Beer
Creating root file system YAFFS2
> Warning: unable to open an initial console. Your "dev/" in your root filesystem seems empty (maybe). Same with the: > No init found message. Did you mount the correct partition as the root filesystem?
@Topper tried changing parameter with /bin/sh, /sbin/init, but no luck, getting Failed to execute /bin/sh. Attempting defaults... I am trying to load kernel 2.6.39 with yaffs as file system, below is kernel log. .... ... NET: Registered protocol family 17 s3c-rtc s3c2410-rtc: setting system clock to 2000-01-06 21:03:48 UTC (947192628) yaffs: dev is 32505859 name is "mtdblock3" rw yaffs: passed flags "" yaffs: yaffs: Attempting MTD mount of 31.3,"mtdblock3" yaffs: auto selecting yaffs2 yaffs: block 8146 is bad yaffs: block 8147 is bad yaffs: block 8148 is bad yaffs: block 8149 is bad yaffs: yaffs_read_super: is_checkpointed 0 VFS: Mounted root (yaffs filesystem) on device 31:3. devtmpfs: mounted Freeing init memory: 100K Failed to execute /bin/sh. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance. Function entered at [<c0025ff8>] from [<c020a90c>] Function entered at [<c020a90c>] from [<c020a1a0>] Function entered at [<c020a1a0>] from [<c00089cc>] Function entered at [<c00089cc>] from [<c0022724>] plz help .
If any solution, please let me know. what could be the wrong? I've tried copying working .config file of original linux (that comes with board), but no luck. Please Help !!
Why don't you just change the rootfs (zImage) available on download pages? http://www.friendlyarm.net/downloads You can use the "unyaffs" utility. ex: mkdir mycustomrootfs unyaffs ./zImages-2011-04-21.img ./mycustomrootfs obs: do this on a linux partition (formatted ext2, ext3,...) Now you can now cd to ./mycustomrootfs and change anything you want. run mkyaffs2image again and good luck. :D Hope this helps.
Hi, Iam using smdk6410 arm11 board.Iam not able to load the yaffs2 image on to the samsung 2k page,1Gb nand flash from uboot prompt by nand write.yaffs. Iam having uboot-1.1.6 version and kernel 2.6 version.Can i get latest package of uboot and kernel for smdk6410 board.Please suggest me. Regards v.Balaji
