Install ucos2 to S3C2440 ARM9
Chau Tri Vu
I install by step by step but it fail, it just show white screen, not show
more.
I press d to download 2440ucos_T35/N35.bin to board but it fail.
lingue_378
Oh, Try your self, and u will see your self!
hix tui cung port chua dc, chi len cai man hinh iphone! het!
nXqd
Toan dan truong minh tu suong tren nay :|
AndreT
Eh what?
nXqd
@AndreT: Have you ported uCos to mini2440 before, we do really need help.
This is the 1st time I port uCos to mini2440. Porting QT and winCE are
quite easy with DNW. One more, do we need linux installed to port uCOs ?
Narayanaraju Samunuri
please help me.. its urgent....
could some one tell how to port ucos-ii on friendly arm kit (S3c2440).
if your know any links please provide...
Thanks and Regards
Narayana raju
Shahid riaz
Better u all try the dnw command (a) absolute user applications. And you
don't need any os installed. because UCos itself is complete os.
Shahid Riaz
brox
Are you sure you mini2440 is equipped with N35 type of LCD? If not, that
might be an explanation!
Waqas Ahmad
Dear Shahid Riaz where are you from........?your email,contact info
.etc?plz
andrés barré
f your rom is greater than 128, the image does not work, will have to
recompile the program
on file   " nand.c "   do this!
STATIC U32 NF8_CheckId(void)
  int i;
  U8 Mid, Did, DontCare, id4th;
  NF_nFCE_L();
   NF_CMD(0x90);
  NF_ADDR(0x0);
  for (i=0; i<100; i++);
  Mid     = NF_RDDATA8();
  Did       = NF_RDDATA8();
  DontCare   = NF_RDDATA8();
  id4th     = NF_RDDATA8();
  NF_nFCE_H();
  switch(Did) {
  case 0x76:
    return 0;
  case 0xF1:
  case 0xD3:
    return 1;
  default:
          return 1;              //  <<  here
    Uart_SendString("Unknown NAND type\r\n");
  //  for(;;);
esto por que la memoria de 256 no es reconocida por el sistema de boot, asi
lo hacemos funcionar igual
andrés barré
this because the memory 256 is not recognized by the boot system, so we
make it work well
andrés barré
STATIC void __RdPage512(U8 *buf)
   unsigned i;
  for (i = 0; i < 1024; i++) {                //  512 x 1024
    buf[i] =  NF_RDDATA8();
and this...
Ramakrishna
what is the sequence of porting ucos2
supervivi128, 2440_w35  is ok
what is the role of VGA1028*768
