Hi, I have a question. How I can install i2c-tools ? thanks.
Qtopia how to install i2c-tools ???
In the Makefile for i2c-tools replace the line: CC := gcc with CC := arm-linux-gcc Run make to build. Then copy the resulting binaries to the FriendlyARM and run them...
This does not work. I compiled with arm-linux-gcc and copied the binaries to 2440. when i run and i2c-tools command it gives this error: line 1: syntax error: "(" unexpected
Found out the way.. You also need to change CC := gcc with CC := arm-linux-gcc OR replace $(CC) with arm-linux-gcc every where in i2c-tools/tools/Module.mk Now run make and copy binery files in i2c-tools/tools/ to your FriendlyARM
Hi, which Python version did you use to compile 2.7 or 3.2? I try to build only py-smbus, with python 3.2 as a first step, before go to compile it for arm. But the command python3.2 ./setup.py build failes with the following errors: running build running build_ext building 'smbus' extension gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fstack-protector --param=ssp-buffer-size=4 -Wformat -Wformat-security -Werror=format-security -fPIC -I/usr/include/python3.2mu -c smbusmodule.c -o build/temp.linux-x86_64-3.2/smbusmodule.o smbusmodule.c: In function ‘SMBus_dealloc’: smbusmodule.c:97:13: error: ‘SMBus’ has no member named ‘ob_type’ smbusmodule.c: In function ‘SMBus_set_addr’: smbusmodule.c:161:39: error: ‘I2C_SLAVE’ undeclared (first use in this function) smbusmodule.c:161:39: note: each undeclared identifier is reported only once for each function it appears in smbusmodule.c: In function ‘SMBus_write_quick’: smbusmodule.c:190:9: warning: implicit declaration of function ‘i2c_smbus_write_quick’ [-Wimplicit-function-declaration] smbusmodule.c: In function ‘SMBus_read_byte’: smbusmodule.c:214:9: warning: implicit declaration of function ‘i2c_smbus_read_byte’ [-Wimplicit-function-declaration] smbusmodule.c: In function ‘SMBus_write_byte’: smbusmodule.c:237:9: warning: implicit declaration of function ‘i2c_smbus_write_byte’ [-Wimplicit-function-declaration] smbusmodule.c: In function ‘SMBus_read_byte_data’: smbusmodule.c:261:9: warning: implicit declaration of function ‘i2c_smbus_read_byte_data’ [-Wimplicit-function-declaration] smbusmodule.c: In function ‘SMBus_write_byte_data’: smbusmodule.c:284:9: warning: implicit declaration of function ‘i2c_smbus_write_byte_data’ [-Wimplicit-function-declaration] smbusmodule.c: In function ‘SMBus_read_word_data’: smbusmodule.c:309:9: warning: implicit declaration of function ‘i2c_smbus_read_word_data’ [-Wimplicit-function-declaration] smbusmodule.c: In function ‘SMBus_write_word_data’: smbusmodule.c:332:9: warning: implicit declaration of function ‘i2c_smbus_write_word_data’ [-Wimplicit-function-declaration] smbusmodule.c: In function ‘SMBus_process_call’: smbusmodule.c:357:9: warning: implicit declaration of function ‘i2c_smbus_process_call’ [-Wimplicit-function-declaration] smbusmodule.c: In function ‘SMBus_read_block_data’: smbusmodule.c:402:9: warning: implicit declaration of function ‘i2c_smbus_access’ [-Wimplicit-function-declaration] smbusmodule.c: In function ‘SMBus_list_to_data’: smbusmodule.c:437:17: warning: implicit declaration of function ‘PyInt_Check’ [-Wimplicit-function-declaration] smbusmodule.c:441:17: warning: implicit declaration of function ‘PyInt_AS_LONG’ [-Wimplicit-function-declaration] smbusmodule.c: In function ‘SMBus_set_pec’: smbusmodule.c:623:37: error: ‘I2C_PEC’ undeclared (first use in this function) smbusmodule.c: At top level: smbusmodule.c:640:9: warning: missing braces around initializer [-Wmissing-braces] smbusmodule.c:640:9: warning: (near initialization for ‘SMBus_type.ob_base.ob_base’) [-Wmissing-braces] smbusmodule.c:642:9: warning: initialization makes integer from pointer without a cast [enabled by default] smbusmodule.c:642:9: warning: (near initialization for ‘SMBus_type.tp_basicsize’) [enabled by default] smbusmodule.c:645:9: warning: initialization from incompatible pointer type [enabled by default] smbusmodule.c:645:9: warning: (near initialization for ‘SMBus_type.tp_print’) [enabled by default] smbusmodule.c:660:9: warning: initialization makes pointer from integer without a cast [enabled by default] smbusmodule.c:660:9: warning: (near initialization for ‘SMBus_type.tp_doc’) [enabled by default] smbusmodule.c:661:9: warning: initialization from incompatible pointer type [enabled by default] smbusmodule.c:661:9: warning: (near initialization for ‘SMBus_type.tp_traverse’) [enabled by default] smbusmodule.c:668:9: warning: initialization from incompatible pointer type [enabled by default] smbusmodule.c:668:9: warning: (near initialization for ‘SMBus_type.tp_members’) [enabled by default] smbusmodule.c:670:9: warning: initialization from incompatible pointer type [enabled by default] smbusmodule.c:670:9: warning: (near initialization for ‘SMBus_type.tp_base’) [enabled by default] smbusmodule.c:676:9: warning: initialization from incompatible pointer type [enabled by default] smbusmodule.c:676:9: warning: (near initialization for ‘SMBus_type.tp_alloc’) [enabled by default] smbusmodule.c:678:9: warning: initialization from incompatible pointer type [enabled by default] smbusmodule.c:678:9: warning: (near initialization for ‘SMBus_type.tp_free’) [enabled by default] smbusmodule.c: In function ‘initsmbus’: smbusmodule.c:694:17: warning: ‘return’ with no value, in function returning non-void [-Wreturn-type] smbusmodule.c:696:9: warning: implicit declaration of function ‘Py_InitModule3’ [-Wimplicit-function-declaration] smbusmodule.c:696:11: warning: assignment makes pointer from integer without a cast [enabled by default] error: command 'gcc' failed with exit status 1
Ok, it tried compile i2c-tools-3.1.0 with Python 2.7 and it work under Ubuntu 12.04. Has anyone an idea how to compile it with Python 3.2 and which changes has to be done in the smbusmodule.c code?
