Anyone tried to compile MySQL for Mini2440? I've got: configure: error: cannot run test program while cross compiling Any ideas? thanks in advance best regards Tom
MySQL cross compilation
I'd found a similar error compiling apr-util for apache: The 'test' program was compiled by arm-linux-gcc on my PC and the PC was trying to run it. I think you will have to compile 'test' program with PC gcc, copy it to the right build directory and try to run the ./configure again. Hope it helps.
Hi eduardo, have you able to compile mysql yet? if so can you provide us a bit more detail. ie: where is test program, where is the right build directory... thanks.
Just comment test stuff in make file or using --notest(or st like that) why dont you try to port sqlite instead of choosing mysql. Porting sqlite3 to mini2440 is quite easy :)
Hi TungPham, I think the test stuff is in ./configure not in make file and if you type ./configure --help you will see no such --notest option. Have you actually compile the code or just a guess. My board is actually tiny6410, I am planning to use mysql 4 or even 3 so the code will be small and fast enough, the main reason is my database server need to be able to handle around 30 hits per second constantly.
I finally able to cross compile mysql to tiny6410 by using scratchbox. I download latest version of scratchbox core. Add arm toolchain for armV4 (tiny6410 won't work with armV7 toolchain). Add library, devkit-qemu. Setup target and away I go. For mysql I have to compile and install ncurse first. Then mysql is compiled without a hitch.
Hi everyone Can you help compile mysql for arm-linux-gcc, i am new here, please i need help, i need mysql client libraries to run on a device with arm processor thank you in advance.
