Hi Every body, Is anyone have tested the brand new QT 4.7 with mini2440. After cross-compile from source, I faced segmentation fault ( OK with QT 4.6.3 ) Thanks,
Segmentation Fault with QT 4.7
Hi! Yes, I've got the same problem with Qt 4.7.0 on an Atmel AT91SAM945-EKES Evalboard: Whenever I start an example with the '-qws'-argument, the mousepointer is drawn on the display, and then the app terminates with segfault. It makes no difference whether I am using LinuxFb or VNC as QWS_DISPLAY. Also tried building Qt 4.7 from Git-branch 4.7 today --> same error. When I use Qt 4.6.3 built with the exact same toolchain (arm-linux-gcc 4.1.2) and configuration (excluding declarative-component of course) everything works just fine. I have no idea where the problem could be. Did you have any luck yet? Regards
I have *exactly* the same problem and have tried the same things, including VNC. Qt samples that don't require QtGUI seem to work fine (like /threads/semaphores), but any sample requring QtGui segfaults. I can cross-debug and place a breakpoint in main, but as soon as execution enters QApplication(), it's segfault time! I've spent 2 days on this with various toolchains, building various options and even in debug mode. I'll follow your recommendation and revert to 4.6.3. Jean-Pierre
In my case, the reason of getting segmentation faults was a wrong ftp transfer mode. Try "binary" instead of "ascii" in your ftp-programm, that worked for me ;)
For Qt's benefits... (hopefully they read this) More info on my build: Angstrom toolchain for Chumby, i.MX23 ARM9 processor, latest Qt 4.7 Problem is "Segmentation Fault" when entering QApplication() running sample /widgets/calculator/calculator -qws Configure & make statement below: date && ./configure -xplatform qws/linux-arm-gnueabi-g++-MX23 -embedded arm -prefix /usr/local/SIM/Qt -I /usr/local/SIM/include -L /usr/local/SIM/lib -qt-gfx-vnc -qt-mouse-tslib -qt-zlib -no-qt3support -no-webkit -no-javascript-jit -no-script -nomake demos -nomake examples -nomake docs -opensource -release && make && make install && date I rebuilt everything for 4.6.3 using the exact same config & setup and finally I have a working system... so there really is something with Qt 4.7 running on ARM. JP
I have the same problem on my mini2440. Now, if I configure with option -no-freetype, it works. (but limited fonts) If I configure with option -system-freetype (using the latest freetype2 lib), it almost works, ie: no segfault. But if I ran the fontsampler application, I can see the name of all fonts, but when I select a ttf, I see only "rectangles" no character. Anyone has clue why I don't the fonts correctly?
Hey Chris! Many thanks for the tip with the '-no-freetype'-option: it works for me now!! Finally, I can try out some QML-UIs on the target (which run surprisingly smooth, btw). Cheers
Dude, from the Chinese page, it's stated that this latest cross compiler which is of EABI standard, "could completely solve the Segmentation Fault issue". http://arm9download.cncncn.com/mini2440/linux/arm-linux-gcc-4.4.3-201007... Would you like to try?
Unfortunately, My build with arm-linux-gcc-4.4.3 didn't work. (segmentation fault). I am trying to build the qt4.7.0 provided by Friendly ARM for mini6410. If this still doesn't work, I will try "-no-freetype" :), thanks for the tip.
Nan Chen, Good work. Now finish the job by writing up a HowTo, as I am sure you will get many requests for how you managed to do it! Which version of mini2440? Might stop someone like me trying to put it on a 64M machine. Regards, Dave
same problem with me("-no-freetype" is OK)
and I cross-compile the freetype2 lib,then re-configured with the option
"-system-freetype" and re-compiled Qt-4.7,download to the board,
test failed.remain the segment fault!!!
anybody tried the Qt-4.7.1??
Guys I´m suffering during the whole week to put Qtopia 4.7 working. I´m stucked on the compiling because somehow someof the files are compiled with the i386 header although the rest of it compile with the ARM headers. Can anybody help me ?
addition:
i tried these compilers: 4.4.3 ,4.4.1, 4.3.2
contact to me with gtalk: memccpy at gmail dot com
Cheetah, Have you switch off the GCC optimization ( -o2 --> -o0 ) in qmake.conf configuration file ? If not, that is probably the issue your are facing
Guys
I get this compiling error. I don't know how the i386 header is being
included. the configure line is:
./configure -verbose -embedded arm -xplatform qws/linux-arm-g++ -prefix
/media/b1cc59e2-c2f4-4a5e-acee-fc4dada4edbe/opt/Boardcon/4.3.3
-qt-mouse-tslib -opensource -confirm-license -nomake examples -nomake
demos -little-endian -no-webkit -no-cups -no-largefile -optimized-qmake
-no-openssl -nomake tools -no-openssl -no-freetype
the qmake.conf file is:
# qmake configuration for building with arm-linux-g++
include(../../common/g++.conf)
include(../../common/linux.conf)
include(../../common/qws.conf)
QMAKE_CFLAGS_RELEASE = -O0 -pipe -msoft-float -mthumb-interwork
-mcpu=arm920t -march=armv4t
QMAKE_CXXFLAGS_RELEASE = $$QMAKE_CFLAGS_RELEASE
# modifications to g++.conf
QMAKE_CC =
/media/b1cc59e2-c2f4-4a5e-acee-fc4dada4edbe/opt/Boardcon/4.3.3/bin/arm-linux-gcc
QMAKE_CXX =
/media/b1cc59e2-c2f4-4a5e-acee-fc4dada4edbe/opt/Boardcon/4.3.3/bin/arm-linux-g++
QMAKE_LINK =
QMAKE_LINK_SHLIB =
-c -include .pch/release-shared-emb-arm/QtCore -pipe -fno-exceptions -O0
-pipe -msoft-float -mthumb-interwork -mcpu=arm920t -march=armv4t
-fvisibility=hidden -fvisibility-inlines-hidden -Wall -W -D_REENTRANT -fPIC
-DQT_SHARED -DQT_BUILD_CORE_LIB -DQT_NO_USING_NAMESPACE
-DQT_NO_CAST_TO_ASCII -DQT_ASCII_CAST_WARNINGS -DQT3_SUPPORT
-DQT_MOC_COMPAT -DQT_USE_FAST_OPERATOR_PLUS -DQT_USE_FAST_CONCATENATION
-DELF_INTERPRETER=\"/lib/ld-linux.so.2\" -DHB_EXPORT=Q_CORE_EXPORT
-DQT_NO_DEBUG -I../../mkspecs/qws/linux-arm-g++ -I. -I../../include
-I../../include/QtCore -I.rcc/release-shared-emb-arm -Iglobal
-I../3rdparty/zlib -I../3rdparty/harfbuzz/src -I../3rdparty/md5
-I../3rdparty/md4 -I.moc/release-shared-emb-arm -I../../include -o
.obj/release-shared-emb-arm/qvariantanimation.o
animation/qvariantanimation.cpp
In file included from animation/qvariantanimation.cpp:694:
../../include/QtCore/qatomic_i386.h: In member function 'bool
QBasicAtomicInt::testAndSetOrdered(int, int)':
../../include/QtCore/qatomic_i386.h:144: error: impossible constraint in
'asm'
{standard input}: Assembler messages:
{standard input}:359: Error: bad instruction `lock'
{standard input}:360: Error: bad instruction `incl [r2,#0]'
{standard input}:361: Error: bad instruction `setne [fp,#-5]'
{standard input}:400: Error: bad instruction `lock'
{standard input}:401: Error: bad instruction `decl [r2,#0]'
{standard input}:402: Error: bad instruction `setne [fp,#-5]'
make[1]: *** [.obj/release-shared-emb-arm/qvariantanimation.o] Error 1
make[1]: Leaving directory `/opt/qtsdk-2010.05/qt/src/corelib'
make: *** [sub-corelib-make_default-ordered] Error 2
Can anybody help me
Macro:
thanks for your reply.
I had tried the "-O1 and -O0",that doesnt help.
the last 2 days, I tried cross-compile libfreetype and change the Qt
configure parameter as "-system-freetype",and result the same fault.
finally I found the cause for this fault.
that is font-related。。
here is three way to avoid this:
a):
delete all ttf fonts in $QTDIR/lib/font (rm -f $QTDIR/lib/font/*.ttf)
or
b):
add a parameter “-fn somefont”to your excuteble program.
like this: $./your_program -qws -fn somfont
or
c):modify your source file.
add a line like this“app.setfont("somefont",15)” after your QApplication
object created.
in these 3 ways.just take one choice can avoid the fault.
the cause maybe in where Qt take the default fonts failed and fallback to a
ttf format font,that problem maybe happens。
when the above program runs Ok,but once you the close the
program,a segfault still will happens 。
can't find out why 。。。。
i found this bug and add a comment on
http://bugreports.qt.nokia.com/browse/QTBUG-13441
congratulations!!!! I have fixed it over。。。 this problem's root cause is the about memory align. modify this source file and recompile: vim $QT_SRC_DIR/src/3rdparty/harfbuzz/src/harfbuzz-global.h ..................... 42 #if defined(__GNUC__) || defined(_MSC_VER) 43 #define HB_USE_PACKED_STRUCTS 44 #endif .......................... just comment the 44th line. #if defined(__GNUC__) || defined(_MSC_VER) /* #define HB_USE_PACKED_STRUCTS */ #endif Never segfault while the program starting up(only with -qws) or closing down. http://bugreports.qt.nokia.com/browse/QTBUG-13395
Hi guys!
Just tried with Qt 4.7.1 - segfault also occurs here.
But when you, as Cheetah discovered, explicitly specify a font for your
application along the lines of
QFont appFont("Bitstream Vera Serif");
app.setFont(appFont);
it works like charm.
@Cheetah: Thanks for sharing this solution.
Nan Chen, if you're still interested on how i got QML to run on my ARM-Board, here's the code for my QML-Viewer: http://pastebin.com/ey3rhzJt
@Michael S. Happy to heard that you worked it out too. Let's keep in touch for further studies... I'm a Chinese guy. My Email:memccpy@gmail.com or QQ:147957232
Guys THese are the steps I took to solve the compilation problem. Thanks to Mr. lars.thornqvist@pdahl.se. make -no-iconv sudo make install -no-iconv Don't know what Im missing and if it's somethig important, but the compilation went through ok. Does anyone have any idea why ?
Trying to build Qtopia 4.7 for mini 2440. Can anybody help me in this error ? /javascriptcore/JavaScriptCore/wtf/TCSystemAlloc.cpp ../3rdparty/javascriptcore/JavaScriptCore/wtf/TCSystemAlloc.cpp: In function 'void* TrySbrk(size_t, size_t*, size_t)': ../3rdparty/javascriptcore/JavaScriptCore/wtf/TCSystemAlloc.cpp:127: error: 'sbrk' was not declared in this scope make[1]: *** [obj/release/TCSystemAlloc.o] Error 1 make[1]: Leaving directory `/opt/qt-everywhere-opensource-src-4.7.1/src/script' make: *** [sub-script-make_default-ordered] Error 2 qmake.conf is: # # qmake configuration for building with arm-linux-g++ # include(../../common/g++.conf) include(../../common/linux.conf) include(../../common/qws.conf) #QMAKE_CFLAGS_RELEASE = -O0 -mfloat-abi=softfp -mcpu=arm920t -march=armv4t -Winvalid-pch #QMAKE_CXXFLAGS -= -std=c++0x -std=gnu++0x QMAKE_CXXFLAGS_RELEASE = $$QMAKE_CFLAGS_RELEASE # modifications to g++.conf QMAKE_CC = /opt/Boardcon/4.3.3/bin/arm-linux-gcc QMAKE_CXX = /opt/Boardcon/4.3.3/bin/arm-linux-g++ QMAKE_LINK = /opt/Boardcon/4.3.3/bin/arm-linux-g++ QMAKE_LINK_SHLIB = /opt/Boardcon/4.3.3/bin/arm-linux-g++ # modifications to linux.conf QMAKE_AR = /opt/Boardcon/4.3.3/bin/arm-linux-ar cqs QMAKE_OBJCOPY = /opt/Boardcon/4.3.3/arm-linux-objcopy QMAKE_STRIP = /opt/Boardcon/4.3.3/bin/arm-linux-strip QMAKE_INCDIR += /usr/local/tslib/include QMAKE_LIBDIR += /usr/local/tslib/lib configure is : ./configure -embedded arm -xplatform qws/linux-arm-g++ -prefix =/usr/local/QT -qt-mouse-tslib -little-endian -no-webkit -no-qt3support -no-cups -no-largefile -optimized-qmake -no-openssl -nomake tools -nomake demo
Any body has problem with the segmentation fault when Qt application exiting? I tried Qt 4.6.3, Qt 4.7.1, Qt 4.7.2 and have the same result :( I am using buildroot, so I think the problem came from uClib but don't know how to fix it. Any help, please.
Hello, I am install a qt qt-everywhere-opensource-src-4.6.3 in my system i am create Hello application and it cross compile and inserted on board and run hello -qws but error is missing lib of qt.How to cross compile the all qt-4 lib for mini2440 board...
If I had a dollar for everything I posted this link! http://mini2440vietnam.blogspot.co.nz/2011/04/upgrade-qt462-in-mini2440....
