Hi, I just downloaded recently uploaded mini6410-android-images-20100922.zip, and installed this image using USB to a mini6410 256MB with 4.3" LCD: - uboot: u-boot_nand-ram256.bin - kernel: azImage_n43 - imagefile: rootfs_android.ubi After the installation. I tried to boot from NAND-Flash independently (not connected to the host computer). The device booted, going through touchscreen callibration procedure, display the character "ANDROID", and stayed there, frozen. so, I tried to boot with the command <b> through serial port. It also stayed frosen displaying "ANDROID", but it went through after a while, and run Android 2.1 successfully. I copied the last part of the hyperterminal log below. Anyone know the cause of the problem, and how to fix it? //******* last part of the log ************ init: cannot open '/initlogo.rle' eth0: link down sh: can't access tty; job control turned off # warning: `rild' uses 32-bit capabilities (legacy support in use) //******** the device was frozen here**************** //******** and wake up after the line below ********* request_suspend_state: wakeup (3->0)
6410 w recent Android2.1 image: boot problem
Maybe you need the u-boot_nand-ram128.bin "-ram256" means the DDR RAM onboard is 256M. It'not Nand flash size.
thanks again Mindee.. my bad, Android 2.1 run well after I replaced the u-boot to u-boot_nand-ram128.bin. I wish the next update to Android 2.2 comes up soon.
