Unable to talk to Mini2440 via DNW
wanderer
Has anyone had trouble communicating with the Mini2440 via DNW? I have two
mini2440 and suddenly I'm not being able to send commands to one of them.
Strange thing is that the mini2440 loads perfect to the OS in flash memory
and when in nor it loads the bios but when I type a command it wont read
it!! Any ideas or suggestions?!
Thanks!!
Andreas Watterott
Maybe its a problem with the serial cable. Have you tried another one?
Regards,
Andreas
wanderer
Yup... I tried with both of my cables and I'm still not able to send
commands via DNW. :(
BePe
I've nearly the same problem. I can't connect the Mini2440 through DNW. I
think the main problem is that the usb driver doesn't work. I tried out
both ways to install the usb driver. The driver setup passed through
without any problems (like it seemed to me). At the manually installation I
copied the "SECBULK.sys" to C:\Windows\System32\drivers and selected the
"SECBULK.inf" at the Windows driver installation interface but it can't
install it. I thought the board may be damaged but as I connected it to a
vga display linux booted up normally. So does anyone have an idea to solve
this problem.
BePe
Well, I got a hint that solved my problem...just switch on the NOR-Flash
and power up the board again. Now my PC recognize the board and even the
driver fits.
Coolkeum
Hi wanderer,
Do you have solve your problem?
From several months, the communication between my mini2440 and DNW works
well but today, I have exactly the same problem as you!
Screwface
I don't know if it helps, but I encountered a similar problem a few days
ago. My mini2440 which has always worked correctly refused to send traces
on PC terminal. I tried on several hosts but got no message from the mini,
even in NOR BIOS mode. For a reason I don't know, when I used the BIOS in a
"blind" way, all the actions I requested were executed correctly but still
with no trace on the terminal.
I plugged the serial cable in the other way, and don't ask me why, it
worked. Now I'm able to get traces on the terminal and send commands to the
mini. I don't know what was the problem as a serial cable should be
symetrical, and I checked before that everything was correctly plugged...
regards
Heard of this happening before.  Try turning the cable around and see if
the problem comes back.
The only thing that comes to mind, if a wire breaks off one terminal AND
then connects to another active terminal I could see the cable "looking"
different from both ends.
raja
hi every one, could u plz help me..
my prob is iam unnable to see the characters clearly when iam connecting to
the mini2440 thru the DNW..showing some unwanted sybols and charecters in
between.same problem when iam trying thru ubuntu also. baudrate used is
115k.. im able to port linux onto mini2440 but my console is not clear...
like this... what should i do to rectify this.... thanks already...
##### FriendlyP
=M2.0 for 244 #####
[] format NAND FLAS for Linx
[v] Download vivi
[k]DownloXbkenel
[W"ݹroot_yaff image
[a] Abslute UserApplicatin
[n"ݹNboot forWinCE
[l] Download WinCE boot-logo
[w] Download Winr-bin
[d] Do+& Ru
[z]Download zmage inoRAM
[g] Boot liux fro
5
[f] Format the nand flsh
[b] Boot th system
[s] Set the bootparametes
[u] Backup NAND Flash to HOST thogh USB(uload)
[r] RestKՁNAND Flash fro[B=MQthrogh USB
[q] Got
of ivi
[Wͥ 1138-2KCCɁyour selecion:
USB host is conne>W  ѥa dowload.
C! Download}ng [ADDRESS:30000000h,TOTAL:249026]
RECEIVE FILE SIZ249026 (23KB/S, 1S)
Downloadd file at 0x3000000, size= 249016bytes
Fond blo-镁= 0x0040000
Erasing..    ... done
Witing...    .. done
Written 249016 bytYHHh2ɥI5BIOS .0 for 2440 #####Hhuforat
NAND FLASH for Linux
[v] Downl+ vivi
[o] Downlad linuxkernel
y] Dowload rootř́imXVj
[a]Absolute User Application
[] Downl+Nbootfor WinCE
[l] Dowload WinCE boot-loo
[wW3ݹWinCE NK.b
j
[d"ݹ&Run
[] Downl+zImage into RAM CVlinuxfrom RAM
[f] FormXnXflash
[b] Bothe systm
[sсthe bot paramters
[] Backup NAND Fl.
HOST through USB(uploXVj
[r] Restore NAND Flash from HOST through U(j
[q]Goto shel of vivi
[i] Vesion: 1138-2K
Entr your sѥ
USB hos is conY,W  ѥa do񽅑
Now, Downoading [ADDRESS:&‚BTOTAL:226626]
RECEIED FILE JU 1 226626 (737KB/S, 3S)
Downloaded ile at 0x30000000 size =2266616 byes
Wrte to fla{h ok: skpped siz = 0x6000, size= 0x2295f8CHh2ɥP
=M2.0 for 240 #####
[x] format NAND FLASH for Liux
[v Download vivi
[k] Downlod linux krnel
[}] Dowl+сroot_yffs imagYj
[a] Abolute User Applicaion
[n] DownloadNboot fo WinCE
[l] Downoad WinCQѵlog
[w] Download WinCE NK.bin
[d] Dwnload & Run
[z Downlod zImage into RAM
[g] Bolinux frm RAM
[f] Formatthe nan flash
[b] Boo the syse
[s] St the boot parameters
[uBackup NAND Flash to HOST ~hrough UB(upload)
[r] Restore NAND Flash frm HOST through USB
[q] Goto shel of vivi
[i] Version: 1138-:K
Enter your selY,WKy
USB hos is concted. WaWa do+
C Dowloading [DDRESS:30000000h,OTAL:9719434]
owladed fil at 0x3000000, sie = 971924 bytes
Flash parms: oobK= 64, oobbloc- b*Ʌ͕ͥ镁= 131072,
pqrtitionsize = 107974656HɅͥand proaming NAND with yaffs image
 Block era{ing(addriչѥ --= Blockbad(addr/count) --Kprk͕Al()
--------------------KKKKKKKKKKKKKKKKKKjzjjjjjjjjjjjjjjjj
     0x00560000/0001            0x0000000/0000           00001/08148=0
ali fattahian
I spend a day to figure out how to resolve this problem and I found really
interesting solution. Do not use usb if you have RS232 connector. because
you have com connector , your operating system find it as COM1 and DNW
communicate with com1. I didn't find usb com number. that is why I prefer
RS232 or com connector.
Reggie
you could just use the onboard com port with your PC, or disable it,
windows will happily allow you to reassign the com1 name to a usb to serial
adapter.
ali fattahian
what I found in loading windows into the board is that you can not program
the device without usb. but I can not see vivi menu without com port. I mix
them (seeing menu with com port and sending data with usb port) and it
really worked.
Gautam
Hi friends,
Check this post for a solution:
http://www.friendlyarm.net/forum/topic/261
Cheers!
Gautam
vengadesh
how do i install dnw for linux host
Putting <dnw linux download> into Google gave me this:
https://code.google.com/p/dnw-linux/
