Hi expert, I am a newbie on embedded system. I am writing a application to test the ADC control of mini2440 using wince 6, but I have no idea how to access it. Anyone could provides an example code in c# for my reference?
How to write a wince program for ADC
Hello, I'm having the same problem, I've found an ADC example on : http://www.thaieasyelec.net/archives/Manual/Example-WINCE-ARM9.zip I've used just the C# one, it gives me the message: "Open ADC1 Driver Fail" and nothing works, but the aplication run's ( if you check after getting a hport = -1, the program don't do nothing ) I think the problem is in the : hPort = CreateFile("ADC1:", GENERIC_READ | GENERIC_WRITE, 0, IntPtr.Zero, OPEN_EXISTING, 0, IntPtr.Zero); line, I don't know the parameters to access the ADC, thanks in advice, Cristiano
Hi Cristiano; you should first change the kernel of your 2440 with WinCE6 from http://www.thaieasyelec.com/sales-and-service-for-WIN-CE.html I cant read the text but you can select your WinCe and download it. for upload winCe to your Hardwear you can read Mini2440.pdf I have no problem with the example Best Regards
Change what, is there a DLL in that CE image? I really like t access to IO on my 6410 ! Can we get the dll source or the compiled dll ?
I run the Example-WINCE-ARM9.zip\LED\C#\LEDsample\LEDsample\bin\Debug\LEDsample.exe and works fine, whoever when I compile the C# Example-WINCE-ARM9.zip\LED\C#\LEDsample\LEDsample.sln than the file is 1k larger and cant open GIO1 !! Anyone know why ? This is on 6410 board..
detail explanation step wise follow this link [url=http://pchardsoft.com/2011/06/how-to-write-a-code-for-wince-application/...]
if you want to use example from www.thaieasyelec.com, you must use image wince6.0 from http://www.thaieasyelec.com/Free-Service-from-ThaiEasyElec/ARM9-mini2440...
Dear Toon, But there should be an ADCdriver.dll File in the Thaieasyelec image, do you have it? or anybody has it? it would ease alot ADC work.
Anyone read it at all ? !! "I run the Example-WINCE-ARM9.zip\LED\C#\LEDsample\LEDsample\bin\Debug\LEDsample.exe and works fine, whoever when I compile the C# Example-WINCE-ARM9.zip\LED\C#\LEDsample\LEDsample.sln than the file is 1k larger and cant open GIO1 !! Anyone know why ? " The precompiled exe works fine, but if I compile with VS2008 the same example not working and the file-size 1kbyte larger !! I got the Dll, registered fine, now I just want to make my own app but even the example they provided not complies a working exe...
Dear bela First Question. Becoz 6410 WinCE Image from FriendlyARM doesn't have GPIO Driver. Second Question plz check define in your code and compare with example.
Hey Joan Y I found ADC Driver and coding from http://www.friendlyarm.net/forum/topic/1954
this link might be helpful for you.try this http://goodtricks4pc.blogspot.in/2012/05/how-to-write-windows-ce-configu...
hi sir.. Im using arm 9 board w35.i want to digitalise audio signal using adc of arm..is it posiiblr
