Hi, Im using keil to compile the source code mini12440test, please reply whether keil startup.s can be used or we should use the 2440test.s provided along with the package. When i tried to compile, it says ROM1 is undefined error, should i need to do some initial settings before compiling, if yes, please let me know the settings what we need to do. Also, please reply with how to flash the code and image file into the board. Im a starter, please reply in brief. Thanks in Advance
No Os Application
you can follow this link: it ises ADS http://www.thaieasyelec.net/archives/Manual/Chapter%204.3%20Compile%20an...
