Hi, I want to known the way for configuring right for device (ex. pwm) on my board. I looking in /etc/udev/rules.d but I don't found the corresponding config file. Do I must create myself ? I do a cgi-bin web script for using pwm, but I must change manualy /dev/pwm right every restart. Thanks
pwm udev configuration
You need to create a driver with the configuration. Look the linux-xxxx/drivers/char/mini2440_pwm.c and compare with the datasheet. Will be helpful.
