I dont know what the modules are to be loaded in the kernel. I use 2.6.32.2 and would like to know the MINIMUM of modules to boot Android from SDcard(and ofcourse, able to use touchscreen and cardreader). Been using a configfile I got somewhere, but it uses the yaffs fs, so I changed it to ext2/3 support in the kernel, but after the ext3 messages, I get this: Waiting 3sec before mounting root device... kjournald starting. Commit interval 5 seconds EXT3-fs warning: maximal mount count reached, running e2fsck is recommended EXT3 FS on mmcblk0p3, internal journal EXT3-fs: mounted filesystem with ordered data mode. VFS: Mounted root (ext3 filesystem) on device 179:3. Freeing init memory: 168K Warning: unable to open an initial console. Kernel panic - not syncing: Attempted to kill init! Backtrace: [<c00369d4>] (dump_backtrace+0x0/0x10c) from [<c02f9844>] (dump_stack+0x18/0x1c) r7:c3820000 r6:c040cd70 r5:0000000b r4:0000000b [<c02f982c>] (dump_stack+0x0/0x1c) from [<c02f9894>] (panic+0x4c/0x134) [<c02f9848>] (panic+0x0/0x134) from [<c0047d98>] (do_exit+0x534/0x62c) r3:c03eeb34 r2:c3823e20 r1:c3823cf4 r0:c03924a4 [<c0047864>] (do_exit+0x0/0x62c) from [<c0047ed4>] (do_group_exit+0x44/0xc4) [<c0047e90>] (do_group_exit+0x0/0xc4) from [<c0052990>] (get_signal_to_deliver+0x19c/0x354) r5:0000000b r4:c3822000 [<c00527f4>] (get_signal_to_deliver+0x0/0x354) from [<c00353e8>] (do_notify_resume+0x9c/0x540) [<c003534c>] (do_notify_resume+0x0/0x540) from [<c0032f68>] (work_pending+0x1c/0x20) And instead of a black screen at first seconds of bootup I get the linux logo. What modules am I forgetting to add (or to remove?)? If someone could upload a configfile, also great! (oh and what is the name of the kernel module for the (VIA VT6656)wifi module?) Regards, Carlos M.
Minimum kernel modules for Android(1.5) SD booting?
Hi, Download kernel source from this web site, in root directory you have config file corresponding to your mini2440 model. Enable Ext3 in your kernel, isn't in default. Show us the boot command line are you using, I think your problem is there.
Hi madmax, Tried different init options (as far as possible, like /sbin/init or something that doesnt even exist haha). Getting different reactions at the same point as before. By the way, I am using the config file from this site, I just changed it myself as the default did not work! I tried ONLY changing the fs, deleting yaffs en adding ext3, didnt work, same error. Changed some more options, no effect. Using default boot options: bootcmd=mmcinit ; ext2load mmc 0:2 0x32000000 uImage.bin ; bootm 0x32000000 bootargs=console=ttySAC0,115200 root=/dev/mmcblk0p3 rootfstype=ext3 mini2440=0tb rootdelay=3 init=/linuxrc It boots with precompiled images from other people, or at least from Belina76's blog. (same settings) Any idea?
