Hi, i am using the toolchain provided on this website: http://friendlyarm.net/dl.php?file=arm-linux-gcc-4.3.2.tgz together with the qtopia image. http://friendlyarm.net/dl.php?file=linux-root_qtopia-64M_20090429.zip I have already compiled my uboot and my kernel: http://friendlyarm.net/dl.php?file=linux-2.6.29-mini2440_20090708.tgz and i am using a SD-Card with an ext3 filesystem for my qtopia. My frienlyArm is booting and also loading qt like normal..... Now i want to have a NCURSES lib on my friendlyArm ( i want to use midnightcommander or IpTraf or something like this.... but first i would be happy if the examples of ncurses would work) i have downloaded the ncurses-5.7 from: http://ftp.gnu.org/pub/gnu/ncurses/ seting up my crosscompiler : export ARCH=arm export CROSS_COMPILE=arm-linux- export PATH=$PATH:/usr/local/arm/4.3.2/bin .... and then i try to compile ncurse: ./configure --target=arm-linux --host ...... --withshared everything was running okay but if i try to execute the files i got a segmentation fault... And here is where i am stucked Thanks for your help
How to crosscompile ncurses-5.7
Are you sure you have libraries builded for ARM? Check with file command. Seems to me you have build it for i386.
I have already compiled it if you want to grab it: http://mini2440.netyxia.net/viewtopic.php?f=9&t=22
@Fabien : thanks. Need to build ncursesw (wide char support) to compile powertop to check on mini2440. Anyway my recipe: CC=arm-linux-gcc ./configure --host=arm-linux --with-shared --enable-widec --with-build-cppflags=-D_GNU_SOURCE make HOSTCC=gcc CXX=arm-linux-c++ Then it works fine ;) marek
I'm trying to compile ncurses-5.9 I'm doing it this way: export CC=/opt/FriendlyARM/toolschain/4.4.3/bin/arm-linux-gcc export CXX=/opt/FriendlyARM/toolschain/4.4.3/bin/arm-linux-g++ export CPP=/opt/FriendlyARM/toolschain/4.4.3/bin/arm-linux-cpp export CFLAGS="-nostdlib -L/opt/FriendlyARM/toolschain/4.4.3/lib/gcc/arm-none-linux-gnueabi/4.4.3 -I/opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi/include/" export CPPFLAGS="-L/opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi/include/" export LDFLAGS="-L/opt/FriendlyARM/toolschain/4.4.3/lib/gcc/arm-none-linux-gnueabi /4.4.3/" ./configure --target=arm-linux --host=x86_64 --prefix=/home/dmelo/friendlyarm/ I'm getting the following output error: /opt/FriendlyARM/toolschain/4.4.3/bin/arm-linux-gcc -DHAVE_CONFIG_H -I../ncurses -I. -L/opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi/include/ -D_XOPEN_SOURCE=500 -D_FILE_OFFSET_BITS=64 -DNDEBUG -I. -I../include -I/home/dmelo/friendlyarm//include/ncurses -nostdlib -L/opt/FriendlyARM/toolschain/4.4.3/lib/gcc/arm-none-linux-gnueabi/4.4.3 -I/opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi/include/ --param max-inline-insns-single=1200 -c ../ncurses/./tinfo/lib_baudrate.c -o ../objects/lib_baudrate.o ../ncurses/./tinfo/lib_baudrate.c: In function 'baudrate': ../ncurses/./tinfo/lib_baudrate.c:226: error: 'CBAUD' undeclared (first use in this function) ../ncurses/./tinfo/lib_baudrate.c:226: error: (Each undeclared identifier is reported only once ../ncurses/./tinfo/lib_baudrate.c:226: error: for each function it appears in.) make[1]: *** [../objects/lib_baudrate.o] Error 1 make[1]: Leaving directory `/home/dmelo/friendlyarm/src/ncurses-5.9/ncurses' make: *** [all] Error 2 Does anyone knows how to solve it?
