Hi, I need an id on mini2440 which should be unique. Is there any way to learn? Thanks, Muhammed ER.
Unique ID
To learn? Well, you can use the mac addreess as a unique id to identify a mini2440... it that what U want?
Unfortunaly, the 2440 (nor the 6410) doesnt have a unique mac address. i suggest writing one to eeprom, that will also survive flash updates remco
By the way anyone know how retrive any unique ID, Serela Number or any other unique information from board? The unique also means that it could not be changed out of manufacturing. Thank you in advance.
Sorry I did not understand. Do you mean that we should use the SD or MMC card's serial number and hash it using SHA1? I need something that can 't be removed maybe an EEPROM. Too bad that EEPROMs can be removed. Ideally this would be a serial number in the CPU, which is the most complicated component to replace.
i'm using the eeprom for that. i've split up some components at differtent boards (IP board, display board and controller board and so on) and placed an eeprom at each. this contains the serial and some other info for the running firmware to start different the needed services. best regards, Willem
