Okay, so I'm playing with uBoot again. I'm confused as to how to flash the kernel and rootfs partitions on my 1GB NAND Flash chip on my Mini2440. (If I scrub the NAND and create the Bad Block Table, it makes 4 partitions: uboot, env, kernel, root on the NAND). At the moment, my current uBoot configuration booting the kernel and rootfs off the SD Card. What I want it to do is boot the kernel off the NAND Flash (in the kernel partition), and then let it boot up into a rootfs off the SD Card, if you know what I mean? What is the commands, and what tools do I need in order to flash a kernel and rootFS image to my Mini2440's NAND Flash? Is it like SuperVivi, load it into RAM then write it to a location (eg. 0x3100000), etc? Or do I use SuperVivi to flash the kernel to the respective partition? (Download Kernel & Download RootFS options?) Cheers, Coburn64
uBoot Questions (Flashing stuff to NAND)
Did you look at http://labs.kernelconcepts.de/Projects/Micro2440/ use :- MINI2440 # nand erase kernel MINI2440 # mmcinit MINI2440 # fatload mmc 0:1 0x31000000 uImage MINI2440 # nand write 0x31000000 kernel to write the kernal So what you want to go is load the uImage file from nand and not SD. instead of :- setenv bootcmd mmcinit \; fatload mmc 0:1 0x31000000 uImage \; bootm 0x31000000 have you tried working out where it is in the memory map and try bootm 0x12312312 etc
Hi , I want to buy friendly arm mini 2440. is 1GB NAND flash is enough for Android or Linux Boot loader ? Please specify any boards that support 2 to 4 GB NAND flash from firendly ARM. Regards, Srinivas
Hi , Please specify any boards that support 2 to 4 GB NAND flash and type of the flash(USB,NAND,NOR) supported by Development boards. Regards, sreenivas
