Hey, So I started developping an alternative to DNW. so far it works fine for downloading, I'm working on the uploading part which works partially. more info here: http://mini2440.netyxia.net/viewtopic.php?f=11&t=2 I just opened a new forum for the mini2440, feel free to ask questions :)
USB upload tool for x64 OS available soon !
Hi, good idea your program but i have some problem. The Mini2440 is regularly found but the tool in upload and in download show me this message: "Got the info we need, now downloading data... Something went wrong... ". can you share the Source code of the source? Thanks!
Hi, I will post the source code pretty soon, I still need to clean it up. Did you start the transfer in supervivi ? For example: reset the mini2440 in NOR mode ##### FriendlyARM BIOS 2.0 for 2440 ##### [x] format NAND FLASH for Linux [v] Download vivi [k] Download linux kernel [y] Download root_yaffs image [a] Absolute User Application [n] Download Nboot for WinCE [l] Download WinCE boot-logo [w] Download WinCE NK.bin [d] Download & Run [z] Download zImage into RAM [g] Boot linux from RAM [f] Format the nand flash [b] Boot the system [s] Set the boot parameters [u] Backup NAND Flash to HOST through USB(upload) [r] Restore NAND Flash from HOST through USB [q] Goto shell of vivi [i] Version: 0945-2K Enter your selection: z USB host is connected. Waiting a download. Then you can start the program and use the upload button in the program it will show: File Information: File Size : 1653944 (1MB) Start Addr : 0x30008000 End Addr : 0x3019bcb8 Checksum : 0xa374 Got the info we need, now uploading data... Done uploading. in supervivi it will show: Now, Downloading [ADDRESS:30008000h,TOTAL:1653954] RECEIVED FILE SIZE: 1653954 (807KB/S, 2S) Downloaded file at 0x30008000, size = 1653944 bytes Upload in the supervivi menu has to be used with the download button (ie backup) Download in the supervivi menu has to be used with the upload button.
Hi Fabien, Great job! I've a problem to connecting mini2440 becasue I do not have any serial ports in my laptop, only usb ports I've. Is it possible to use only your tool to upload Windows CE image into mini2440 by usb port? or still need a serial connection ? Regards
Hey, As Rob stated, you'll need a serial port in order to tell supervivi where to download/upload the data. Thanks :)
Hi, Thankyou so much for your effort with this. I downloaded the new version 0.2. I also get the "Got the info we need, now downloading data... Something went wrong... " error almost every time I do an upload to the micro2440. I have successfully downloaded a Boot Logo once but can't repeat this and have not ever been able to send the nboot or nk.bin. To successfully send the boot logo I started it in Administrator mode. But I can not repeat this. I am using the same version of Supervivi (0945-2K) I am using DNW to send the serial port commands and I get the response "Enter your selection: w USB host is connected. Waiting a download." But it just sits there and I have to control C to get out of it. If there's anything I can help with to give more info on this let me know.
Hey, I haven't tested the logo upload feature as I'm only using linux with the mini. I'll try to figure how it works this weekend. Please ask for support on my forum, it makes it easier for me. Thanks.
Hey, There is a new version available, with a serial console embedded, just like DNW. @BBBB, I just realized that you were using the wrong button (download instead of upload)
why i can't see the download link in your website??I've register but don't see any reply letter??How can I get it,please!!
The new download tool seems very good! I registered the forum, but my account has not been activated yet. Could you please activated it? Thank you.
Hey, All accounts have been activated. You may not have received notification emails, I had some problems moving to a new smtp.
"You do not have the required permissions to view the files attached to this post." Registering is a problem.
Hi, I can't download from http://mini2440.netyxia.net/viewtopic.php?f=11&t=2. It doesn't work. Can you have a different link? Where can I download drivers for win7 x64? tnk
Hi, I am also facing same problem.. I can't download from http://mini2440.netyxia.net/viewtopic.php?f=11&t=2 It says The website that you contact is currently undergoing maintenance. Can you have a different link? Where can I download drivers for win7 x64? tnk
Hi all, The code and binaries are all available here if needed: http://code.google.com/p/supervivi-transfer-tool/
