Mini2440 update(2010-08-18) =========================== - change the cross toolchain: arm-linux-gcc-4.4.1(EABI) - add QtE-4.6.3 in Qtopia-2.2.0, easy switch to run. - add NEC 4.3"LCD driver inLinux - fixed a bug in Supervivi, now can use "z" to download bigger zImage - improve the speed to burn NK.bin in supervivi - fixed a bug in the UART1 driver in WindowsCE5 - add english version solution demo in WindowsCE5/6 - add "USB WiFi Kits",support the following type now: >>TP-LINK * TL-WN321G+ * TL-WN322G+ * TL-WN422G+ * TL-WN721N * TL-WN722N >> QCOM * LR802UKG download link: ============ 1. cross toolchain: http://arm9download.cncncn.com/mini2440/linux/arm-linux-gcc-4.4.3-201007... 2. Linux kernel source code http://arm9download.cncncn.com/mini2440/linux/linux-2.6.32.2-mini2440-20... 3. QtE-4.6.3 http://arm9download.cncncn.com/mini2440/linux/arm-qte-4.6.3-20100802.tar.gz 4. WindowsCE 5 BSP http://arm9download.cncncn.com/mini2440/wince5/mini2440-ce5-20100817.zip 5. WindowsCE 6 BSP http://arm9download.cncncn.com/mini2440/wince6/Mini2440-CE6-Suite-1033.zip 6. USB WiFi Kit http://arm9download.cncncn.com/mini2440/linux/mini2440-usb-wifi-kits-201... 7. Supervivi http://arm9download.cncncn.com/mini2440/supervivi-1026.zip 8. target file system (include Qtopia-2.2.0 & QtE-4.6.3) http://arm9download.cncncn.com/mini2440/linux/rootfs_qtopia_qt4-20100816... 9. Linux image : http://arm9download.cncncn.com/mini2440/mini2440-linux-image-20100817.zip 10. WindowsCE5 image(English) http://arm9download.cncncn.com/mini2440/mini2440-ce5-en-image-20100818.zip 11. WindowsCE6 image(English) http://arm9download.cncncn.com/mini2440/mini2440-ce6-en-image-20100818.zip
Nice lot of updates! What is the minimum size mini2440 this will run on? With QtE4.6.3 and 2.2.0 I am guessing 128M?? Cheers, Dave
rootfs_qtopia_qt4.img size is 87.8M, with 128M no problem. and all the things can work on micro2440 too, but at least 128M nand flash mindee
Dear mindee: What are the updates or improvement made to this BSP release for Windows CE 6?. Is it the same that you have on your downloads page under "WinCE 6 BSP 2010-06-09" name?. Where can we get an official "Rivision Note" where we can find the new features added to the BSP each time than a new release is isued?. Thanks in advance and best regards.
Dead Mindee: I`ve download the 3 new images(supervivi, kernel, rootfs-qtopia-qt4, everything OK, but the system boots with the the old qtopia 2.2.0 What am I doing wrong? thanks
As far as I know, qtopia version in that package is 2.2.0 (latest). What you might be confused about is the QT version which is 4.6 in this package. QT and Qtopia are different things.
I have 128MB mini2440, rootfs_qtopia_qt4.img 86MB gives me [Error:File Size Error] in DNW when I use the option "y" to download it. I had to quit DNW cause it stuck that way. rootfs_qtopia_qt4-20100816.tar.gz cannot be downloaded directly onto mini2440 using "y" before being processed by mkyaffs2image. It's too much effort. I did not even try it. If you just flash it onto mini2440 using "y", you won't be able to boot up mini2440 anymore. To fix boot-up issue, my only solution is to redo everything: format NAND, download vivi, download zImage, download root_qtopia-128M.img Without a full "redo", if you use a terminal simulator program like Putty to check linux boot-up, even if it does boot-up, there are many bad blocks. "bad blocks" doesn't seem to affect my system, but I don't like it...
Does anyone have a link to a WiFi USB dongle and driver for the mini2440 running Windows CE 5.0? Have looked everywhere and not finding anything :(
I tested the VIA VT6656 USB WiFi Module, and it works well under WinCE 6. You should test it on 5.0.
Hi, I have tried the updated English version of WinCE5.0. It works very well except for one small probelm. The OS doesn't seem to have a driver for a USB flash drive. The USB port works fine with a mouse & with a keyboard. Is there a driver available for a USB flash drive? If so can someone please point me in the right direction.
Hi, it's very usefull image for my mini2440 i was downloaded WindowsCE6 image(English) from the first post link, and my mini2440 can boot with nboot_T35.bin,NK_T35.bin. but after finished flash NAND, my mini2440 has wrong display orientation. can you give me image with landscape display orientation. many thanks. :)
