Hi, I have a Mini2440 7'' LCD device with 256M NAND FLASH. I've been working with the WinCE image present on the CD attached to the device. I recently succesfully installed uboot for developing aims to try loading some other OS images. Now that I wanted to get back to supervivi, i had no ohter option than using H-JTAG. I did so, and now I have supervivi again. But not the same version as long as options available in command line when booting in NOR mode are not the same. Anyway, the problem is that now I can upload a WinCE image to the device. After loading the image into flash via USB, the device starts the OS. But when I reboot the device in NAND mode as usual, nothing happens. It seems that the image is gone or that supervivi is not doing it's tasks right. I've tried restoring one of the backups of the NAND flash again and again, but it seems to me that the problem is on supervivi. I've tried to load vivi again through USB when booting on NOR mode, but this has no effects at all. Can anyone tell if one have to set up some parameters on H-JTAG for supervivi to work well? Thanks.
