Mini6410 update(2010-08-04)
mindee
- add backlight control in u-boot, turn off the backlight when boot.
- improve the UART driver, now support 4 uart in linux
- update to the latest QtE-4.6.3
- fixed the bug on  NFS boot.
- add OpenGL 3D demo in windowsCE6(no source code)
- add English, Traditional Chinese version solution/mini6410.pbxml in
WindowsCE6
- and include the last update(2010-07-25)
- add the LCD driver for LCD2VGA(1024x768, 800x600, 640x480), T35, L80,
EZVGA, for linux, WindowsCE6
- add PWM, LED, Buttons driver in WindowsCE6
- add Multimedia Test demo in WindowsCE6
download link:
1. the whole iso image(5.5GB):
http://arm9download.cncncn.com/mini6410/mini6410-all-20100804.iso
2. u-boot source code
http://arm9download.cncncn.com/mini6410/linux/u-boot-mini6410-20100730.t...
3. linux kernel source code
http://arm9download.cncncn.com/mini6410/linux/linux-2.6.28.6-20100802.ta...
4. arm-qte-4.6.3 source code: include the script "build" & "mktarget"
http://arm9download.cncncn.com/mini6410/linux/arm-qte-4.6.3-20100802.tar.gz
5. rootfs:
http://arm9download.cncncn.com/mini6410/linux/rootfs_qtopia_qt4-20100802...
6. WindowsCE6 BSP
http://arm9download.cncncn.com/mini6410/wince6/Mini6410-WinCE6-Suite-103...
7. linux image
http://arm9download.cncncn.com/mini6410/mini6410-linux-image-20100802.zip
8. wince6 image
http://arm9download.cncncn.com/mini6410/mini6410-ce6-ch-image-2010802.zip
Andreo
hi,
is there a link collection like this for mini2440?
mindee
please check here:
http://www.arm9.net/download.asp
ps, I can't edit what I typed, how to do?
Phil_in_China
Mindee
Do you have an English version of CE6?
Xie Xie
Phil
mindee
hi, Phil
maybe next time.
MrPec
The download speed is extremly slow. Is there a way to upload those files
to a file hoster or another location?
MrPec
Where can we get the superboot.bin file?
mindee
please try this link:
http://arm9download.cncncn.com/mini6410/superboot-20100808.zip
Max_egodom3
I succeed in download Wince6 BSP, but I didn't find nothing for LCD
backlight driver.
I mean driver to power off lcd backlight when no one touch the screen for a
while (for wince).
Thanks to all.
MrPec
I can't get the board to be flashed with a sd card. Because of the
exrtemely slow download speed i'm unable to download the hole iso. Instead,
I downloaded the wince image alone (mini6410-ce6-ch-image-2010802) and
tried to create the right sd card image with it.
I prepared the card with the sd-flasher utility and the above posted
superboot-20100808.bin.
After that, I created the images folder and put the wince6 file into a sub
folder (WindowsCE6). I also tried putting them right into the images
folder.
Where do I have to put the FriendlyARM.ini file? Into the images folder? Or
in the root of the sd card? Could someone post a FriendlyARM.ini sample? Do
I need all images within the sd card(linux, wince, android) or only the
image i'm going to start?
Thanks in advance,
MrPec
mindee
Hi, Mrpec
FriendlyARM.ini should be in the images folder
MrPec
Ok, I tried that, but without success. Could someone please pot a sample
Martin
Is there any way to get the OpenGL 3D demo WindowsCE6 source code ?
I sucessfully compiled the OpenGL ES Demo (SMDK6410\SAMPLES\OPENGLES) but
the executable does not seem to get started ! And I do not understand why !
Visual Studio displays the error: "The process can not be found!"
Has someone managed to run this demo ?
Also, do I need DLLs (libEGL.dll, libGLESv1_CM.dll) ? Because they are not
in the project (SDK) !!!
peter babu
Hi ,
 Can anyone send me  FriendlyARM.ini file  to this following  mail id .
peter@sblsoftware.com
thanks & regards
Peter
stefanSK
I have the same problem as Martin.I copied the DLLs into the directory
where the executable, but the same result - the program will not start.
Does anyone have any idea ?
