Can anyone tell me how to deploy or install sqlite on mini2440 after cross compiling it
Installing SQLITE on minni2440
To make it work I had to copy driver from compiled libraries. It's in the same folder as all QT libraries but not in 'lib' but in 'plugins'. In 'plugins You have 'sqldrivers'. Just copy 'plugin' folder to the same place as You've copied libraries (You will have two folders: 'lib' and 'plugins'). And You can use Your SQLite databases. good luck best regards Tom
Thanks for the reply Tom. I am having micro2440 SDK board having processor S3C2440. Following are the steps which I had followed. Cross Compile: ./configure target=arm-linux make make install DESTDIR=~/sqlite This created the installation files in sqlite folder. Following are folders that was created after installation under sqlite: usr/local/bin usr/local/include usr/local/lib usr/local/share Then I copied this installation folders to development board (micro2440) in the respective folders i.e under usr/local using flash drive Then in terminal I typed command as sqlite3. It gave me following error: /usr/local/bin/sqlite3: line 1 : syntax error: word unexpected (expecting ")") can you please tell me what is actually going wrong. Is it that my cross compilation for sqlite is wrong?
I have more parameters in my configure:
./configure --prefix=/home/sqlite/sqlite --host=arm-linux
CC=arm-none-linux-gnueabi-gcc AR=arm-none-linux-gnueabi-ar
STRIP=arm-none-linux-gnueabi-strip RANLIB=arm-none-linux-gnueabi-ranlib
CFLAGS="-march=armv4t -mtune=arm920t -Os -lpthread -lrt" LDFLAGS=${LDFLAGS}
CFLAGS are importatant, they determine architecture. Just change --prefix
parameter. Then 'make' and 'make install'.
good luck
best regards
Tom
Hi. I compile the SQLite 3.7.14 with Tom instructions. In device add Sumeet folders to PATH: [root@FriendlyARM sqlite]# $PATH sh: /sbin:/usr/sbin:/bin:/usr/bin: not found [root@FriendlyARM sqlite]# export PATH=/usr/local/bin:$PATH The result: [root@FriendlyARM sqlite]# sqlite3 --help sqlite3: error while loading shared libraries: libsqlite3.so.0: cannot open shared object file: No such file or directory What is wrong? Regards.
Hi. I try create a link. [root@FriendlyARM lib]# rm -rf libsqlite3.so.0 [root@FriendlyARM lib]# ls -lh [root@FriendlyARM lib]# ln -s /usr/local/lib/libsqlite3.so.0 /usr/local/lib/libsqlite3.so.0.8.6 ln: /usr/local/lib/libsqlite3.so.0.8.6: File exists The file libsqlite3.so.0 was not created. What is wrong? Regards.
Hi. This does not work yet. --- [root@FriendlyARM /]# cd /usr/local/lib/ [root@FriendlyARM lib]# ln -s libsqlite3.so.0.8.6 libsqlite3.so.0 [root@FriendlyARM lib]# export PATH=/usr/local/bin:$PATH [root@FriendlyARM lib]# sqlite3 --help sqlite3: error while loading shared libraries: libsqlite3.so.0: cannot open shared object file: No such file or directory [root@FriendlyARM lib]# export PATH=/usr/local/lib:$PATH [root@FriendlyARM lib]# sqlite3 --help sqlite3: error while loading shared libraries: libsqlite3.so.0: cannot open shared object file: No such file or directory --- What is wrong?
Hi. I try create a link. [root@FriendlyARM lib]# rm -rf libsqlite3.so.0 [root@FriendlyARM lib]# ls -lh [root@FriendlyARM lib]# ln -s /usr/local/lib/libsqlite3.so.0 /usr/local/lib/libsqlite3.so.0.8.6 ln: /usr/local/lib/libsqlite3.so.0.8.6: File exists The file libsqlite3.so.0 was not created. What is wrong? Regards. i need sqlite3 command still not working, what i do..
