Dear all, I am using android 2.1 kernel and filesystem.. I am using u-boot to port Android to mini2440 from SD Card..I am getting the boot log as follows..Data from Binder IPC not transferred to target..Check my boot log and say me if there is any idea about this,...... --------------------------------------------------------------------------- trying to detect SD Card... Manufacturer: 0x1e, OEM "AB" Product name: "SDC ", revision 1.0 Serial number: 1124083767 Manufacturing date: 10/2009 CRC: 0x3c, b0 = 1 READ_BL_LEN=15, C_SIZE_MULT=7, C_SIZE=3453 size = 2329935872 1999440 bytes read ## Booting kernel from Legacy Image at 31000000 ... Image Name: Linux-2.6.27 Created: 2010-08-01 9:20:25 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1999376 Bytes = 1.9 MB Load Address: 30008000 Entry Point: 30008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux........................................................................... ........................................................ done, booting the kernel. Linux version 2.6.27 (root@prem-laptop) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #298 PREEMPT Sun Aug 1 14:50:22 IST 2010 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177 Machine: SMDK2440 Memory policy: ECC disabled, Data cache writeback CPU S3C2440A (id 0x32440001) MM: CPU does not support supersection mapping for 0x55000000000 at 0xf0d00000 S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz S3C24XX Clocks, (c) 2004 Simtec Electronics CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on CPU0: D VIVT write-back cache CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: console=ttySAC0,115200 root=/dev/mmcblk0p3 rootfstype=ext3 mini2440=1tb rootwait init=/linuxrc irq: clearing pending status 02000000 irq: clearing subpending status 00000003 irq: clearing subpending status 00000002 PID hash table entries: 256 (order: 8, 1024 bytes) timer tcon=00500000, tcnt a4ca, tcfg 00000200,00000000, usec 00001e57 Console: colour dummy device 80x30 console [ttySAC0] enabled Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 60256KB available (3832K code, 640K data, 116K init) SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 Calibrating delay loop... 201.93 BogoMIPS (lpj=504832) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok net_namespace: 288 bytes NET: Registered protocol family 16 S3C2410 Power Management, (c) 2004 Simtec Electronics S3C2440: Initialising architecture S3C2440: IRQ Support S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics DMA channel 0 at c4800000, irq 33 DMA channel 1 at c4800040, irq 34 DMA channel 2 at c4800080, irq 35 DMA channel 3 at c48000c0, irq 36 S3C244X: Clock Support, DVS off SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered NET: Registered protocol family 1 NetWinder Floating Point Emulator V0.97 (double precision) ashmem: initialized NTFS driver 2.1.29 [Flags: R/W DEBUG]. yaffs Aug 1 2010 14:47:44 Installing. msgmni has been set to 117 io scheduler noop registered io scheduler anticipatory registered io scheduler deadline registered io scheduler cfq registered (default) s3c2410fb_set_par! Console: switching to colour frame buffer device 30x20 fb0: s3c2410fb frame buffer device adc\0x09initialized input: buttons as /devices/virtual/input/input0 buttons\0x09initialized leds\0x09initialized s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440 s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440 s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440 brd: module loaded loop: module loaded nbd: registered device at major 43 logger: created 64K log 'log_main' logger: created 256K log 'log_events' logger: created 64K log 'log_radio' dm9000 Ethernet Driver, V1.31 Now use the default MAC address: 08:90:90:90:90:90 eth0: dm9000e at c4804000,c4806004 IRQ 51 MAC: c38b8934 (friendly-arm) usbcore: registered new interface driver zd1211rw usbcore: registered new interface driver zd1201 Linux video capture interface: v2.00 ovcamchip: v2.27 for Linux 2.6 : OV camera chip I2C driver usbcore: registered new interface driver ov511 ov511: v1.64 for Linux 2.5 : ov511 USB Camera Driver Driver 'sd' needs updating - please use bus_type methods S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c2440-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit) NAND_ECC_NONE selected by board driver. This is not recommended !! Scanning device for bad blocks Bad eraseblock 333 at 0x029a0000 Bad eraseblock 505 at 0x03f20000 Creating 4 MTD partitions on "NAND 128MiB 3,3V 8-bit": 0x00000000-0x00060000 : "supervivi" 0x00060000-0x00260000 : "Kernel" 0x00260000-0x40260000 : "root" mtd: partition "root" extends beyond the end of device "NAND 128MiB 3,3V 8-bit" -- size truncated to 0x7da0000 0x00000000-0x40000000 : "nand" mtd: partition "nand" extends beyond the end of device "NAND 128MiB 3,3V 8-bit" -- size truncated to 0x8000000 s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. s3c2440-usbgadget s3c2440-usbgadget: S3C2440: increasing FIFO to 128 bytes mice: PS/2 mouse device common for all mice usbcore: registered new interface driver appletouch input: s3c2410 TouchScreen as /devices/virtual/input/input1 s3c2410 TouchScreen successfully loaded S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0 i2c /dev entries driver s3c2440-i2c s3c2440-i2c: slave address 0x10 s3c2440-i2c s3c2440-i2c: bus frequency set to 98 KHz s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter mapped channel 0 to 0 s3c2440-sdi s3c2440-sdi: powered down. s3c2440-sdi s3c2440-sdi: initialisation done. s3c2440-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). usbcore: registered new interface driver hiddev s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). usbcore: registered new interface driver usbhid usbhid: v2.6:USB HID core driver UDA1341 audio driver initialized failed to get memory region resouce s3c2410-iis: probe of s3c2410-iis.0 failed with error -2 TCP cubic registered NET: Registered protocol family 17 s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). RPC: Registered udp transport module. RPC: Registered tcp transport module. s3c2440-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). s3c2440-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). mmc0: new SD card at address b368 mmcblk0: mmc0:b368 SDC 980992KiB mmcblk0: p1 p2 p3 s3c2410-rtc s3c2410-rtc: setting system clock to 2010-08-02 11:15:21 UTC (1280747721) EXT3-fs warning: maximal mount count reached, running e2fsck is recommended kjournald starting. Commit interval 5 seconds EXT3 FS on mmcblk0p3, internal journal EXT3-fs: recovery complete. EXT3-fs: mounted filesystem with ordered data mode. VFS: Mounted root (ext3 filesystem). Freeing init memory: 116K Warning: unable to open an initial console. ts_control_open! ts_control_release! init: cannot open '/initlogo.rle' sh: can't access tty; job control turned off / # init: cannot find '/system/bin/playmp3', disabling 'bootsound' init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery' warning: `rild' uses 32-bit capabilities (legacy support in use) g_file_storage gadget: File-backed Storage Gadget, version: 7 August 2007 g_file_storage gadget: Number of LUNs=1 g_file_storage gadget-lun0: ro=0, file: /dev/block/mmcblk0p1 fb_mmap! binder: release 892:892 transaction 882 out, still active binder: 819:895 transaction failed 29189, size 4-0 binder: send failed reply for transaction 882, target dead --------------------------------------------------------------------------- I can see the display in some chineese language, but cannot operate any application properly..
Android-2.1 Booting Log- Unable to send Data..
Hi svprem, If you want to change language you can do it in /default.prop. Country US Language en_US Mini2440 struggles with 64MB android. My guess is the bider error is due to memory shortage. Update me if you had any luck. Regards Saravana
if anybody have load the android on mini2440 so please help me for load and compiling the tarball related to it.
binder: release 892:892 transaction 882 out, still active binder: 819:895 transaction failed 29189, size 4-0 binder: send failed reply for transaction 882, target dead who can tell me what means of above?
