BSPs difference
Ferite
Hi to all:
I was wonder what is the difference between the BSP that you can download
from Google Code Site (MINI2440BSP.exe) and the one you find in the Domodom
site (Mini2440-CE6-Suite-1001.exe). The first is slightly larger than the
second.
Thanks in advance.
Errol
If i'm not mistaken then Mini2440-CE6-Suite-1001.exe is the stock BSP
supplied by FriendlyArm, the one on Google I created from the stock BSP but
I integrated some fixes from the forum.
See http://www.friendlyarm.net/forum/topic/682
Ben
There is also a small description in the wiki
http://code.google.com/p/friendlyarm/wiki/EnglishBSP
Ferite
Hi.
Errol, actually Mini2440-CE6-Suite-1001.exe is your fixed BSP. Only want to
know what is different in Domodom's BSP.
Thanks.
Ben
Mini2440-CE6-Suite-1001.exe is the original FriendlyARM BSP.
Errol
More interestingly, what has changed in wince6-bsp_20100609.zip from the
downloads page? :-)
Andreas Watterott
As far as I know there are only some changes on the display drivers.
Ferite
Errol:
the downloads page? :-)
Yes, I have didn't notice that there was a new BSP from 06/09/2010.
Unfortunately it seems like there is not Revision Notes.
I would like to know if someone has tested the stability of these BSPs in
7/24 applications?
domodom
The BSP available on my website is a old BSP (= the one available when i
wrote my tutorials).
The BSP from Errol is far better.
If you need to see differences betwen BSPs, you just have to compare the
content of each one with a software like windif.
domodom
Ferite
Dominique, Thanks for your clarification about your BSP and the Errol's
one.
I was wonder if anybody has tested the June 9 BSP. Besides the display
driver changes that Watterott mentioned, would be another improvements?
Dupa
How bsp for mini2440 use to eventually generate nk.bin the platform
builder.
