I am using mini2440 system with 128MB flash. I built a target filesystem directory (say target_root_dir) and mounted it via NFS it loads fine. when I use the directoy to build JFFS2 image and load it into NAND flash it will not boot. I am getting 2 errors. a) Unable to open initial console b) Unable to find /linuxrc JFFS2 image command : mkfs.jffs2 –lqnp –e 16 –r target_root_dir –o rootfs_jffs2.img How to debug this problem ? Ramgopal Kota
Block Erase : (128K + 4K)Byte for your flash. Try changing the 16 to 128. 16 is 16K erase block size for the flash in a 64M dev board.
please help me on this aspect Unable to open initial console after all installation my screen is not showing any signs of display m in big trouble please help
Run a "cp -a /dev/console /dev/null /dev/zero <path/to/your/nfsroot>/dev" Your kernel is missing the "/dev/console" device node. Or enable CONFIG_DEVTMPFS in your kernel config (if you are using a recent kernel). This will create the "/dev/console" for you.
