Hi, I need a way to stream a live capture from camera to an internet key (it's a USB UMTS link). There are driver for this key for win and also linux. I've see the micro2440, but the dev board is too big and probabily will add too much weight. Because i need "only" to use the camera, an USB host and one analogic or digital input and one output (better if serial TX and RX), is there a way to do this? I'm not looking fot THE solution, i just wanna know if it is possible and if someone have tryed something similar thank you
micro2440 stream camera to wireless
hello lesto are u able to stream images over internet? from where u got the driver. please share the info, I am trying similar. regards, Nir
Dear, Maybe the post is a bit old and you have probably found a solution, but do you have tried mjpg-streamer? Regards
