Hi, I am a newbie with hardware and inner workings of OS, so please excuse my ignorance. I am wanting to buy a AT070TN83 V.1 LCD panel (not the friendlyARM one) and connect it to the board myself (for fun, learning, and it's cheaper). Is there anything else besides just mapping the appropriate pins? Also, what if I wanted another LCD panel (not the ones friendlyARM use), do I need drivers for them? I understand different LCD panels have different timings. But, there is also a standard. What is this standard? Is is VESA? What if I want to use Windows CE .60, do I need different drivers for that, or does Windows work with any LCD? What about LCD drivers for the linux kernel? Will any LCD following a standard work in Windows or Linux? I know it's a lot of questions, but I am not finding much articles about my questions online. Maybe I am using wrong key words. Thanks for any help,
Using Different LCD Panel
Hey, The circuit diagram for the A7 LCD is on the download page. That will be a good starting point. There isn't really a standard for LCD, not as far as i know. Most LCDs use unique timings. You will need "drivers" for your LCD, but that just entails changing the timing settings in the source for the display in WinCE or Linux. I only know WinCE. You can download the BSP from this site. It contains the drivers for the mini2440. You look in s3c2440a_lcd.h in MINI2440\SRC\INC. These are the settings for the normal 7" LCD: #define LCD_PIXCLOCK 2 #define LCD_RIGHT_MARGIN 67 #define LCD_LEFT_MARGIN 40 #define LCD_HSYNC_LEN 31 #define LCD_UPPER_MARGIN 25 #define LCD_LOWER_MARGIN 5 #define LCD_VSYNC_LEN 1 Thanks, Errol
Hi, Thank you for the valuable information. Does this mean I can use any TFT LCD as long as the resolution is supported by the S3C2440A? Can you or anyone give information on what to look out for when considering a different LCD for this ARM proc? I saw the schematics for the A70 included in the CD. I have some questions What are the things labeled LCD and LCD3 referring to? It says CON40 under them, but I see no connector labeled CON40 on the board. Is there some other friendlyARM board with this connector? Other than that, I can just connect the appropriate pins form the ARM board (LCD41P) to the LCD panel (HEADER 25X2) right? Also, it looks like a Touchscreen can be connected to CON3 & 4 correct? However, for CON1, there are capacitors, so does this mean I need capacitors for CON3 & 4? I have downloaded WinCE6.0 BSP and seen the file(s) you had referred to. Looks interesting. Looks like the values are tuned for the A70, cause I don't see all of them matching to the ones in the datasheet. I had done some searching and found that these timings are used for programming the framebuffer. I found a document, and was wondering if this is a good starting point; http://tinyurl.com/34bmsge Regards Attached is the AT070TN83 circuit schematics.
OK correction. so LCD3 corresponds to the AT070TN83 V.1 pinouts. I don't know what LCD and LCD2 correspond to.
I did some calculations out of curiosity on how the timings are calculated using this guide/diagram I found: http://processors.wiki.ti.com/index.php/LCD_RGB_640x480_VGA_Addition using the AT070TN83 datasheet, I calculated x_res = 800 left_margin = 40 right_margin = 40 hsync_len = 48 y_res = 480 upper_margin = 29 lower_margin = 13 vsync_len = 3 however, in the BSP #elif defined(LCD_A70) #define LCD_PIXCLOCK 2 #define LCD_RIGHT_MARGIN 67 #define LCD_LEFT_MARGIN 40 #define LCD_HSYNC_LEN 31 #define LCD_UPPER_MARGIN 25 #define LCD_LOWER_MARGIN 5 #define LCD_VSYNC_LEN 1 What am I doing wrong?
Theoretically you can use any TFT LCD, upto the max pixels supported by the CPU, i think that is around 800X600, maybe 1024X768. If it is parallel then it can connect directly. If it is LVDS then you will need a parallel to LVDS convertor. Also, the CPU's LCD signals are 3.3V, some LCDs need 5V, then level shifting might be required... The 3.5" LCD board contains a simple CPU to control power up sequencing for the power supplies. Some other LCDs might require that too. I have no idea how the calculations work, I have never tried to figure them out. :-). I just know where they are. I have an LCD i want to connect, but have not gotten around to making an FFC cable adaption board. I can't see that wrong settings will damage the LCD, it might just shift the LCD to one side, or cause rolling etc CON3/CON4 connects to the same pins on the LCD41P as the CON1, so the caps are already present. Are you using the A70 PCB? If you design your own PCB then you will need to add the caps for the touch screen. If i remember correctly then the connecter called "LCD" isn't soldered on the board, the LCD connects to "LCD3". Also, the switching supply on the top right corner isn't on the PCB. On my A70 board the LCD connects to LCD3, the LCD2 connector sits on the side of the board, looks like it is designed for connecting other LCDs to the board.
Hello, i am a final year electronics student doing a project on Arm9 processor.I bought tis processor directly from china and without the display. i want to interface it with either a Car TFT or photo album.Is this possible??if it is..can anyone help me with the particlars needed for that lcd interface.i mean what kind of adapters or drivers should i use to make the arm talk with the LCD??
Thank you for the guidance and help Errol. The schematic and requirements are making much more sense now. You are right about the top right circuit, this LCD doesn't have any LED+/LED- pins. I am also going to try and see if ADV7125 (Digital to Analog for VGA out) works. It's like 10 bucks for the chip. Whereas the VGA board provided by friendlyARM is about 50 bucks. I want to see if I can make one of my own. Regards
Hi all, I'm trying to use a 12.1" LG panel, but I'm having trouble to compile WinCE to show anything on it. In the datasheet (part number is LB121S03) I have hsync front and back porch, same with vertical timings, and a resolution of 800x600 pixels. After compiling and loading the OS in the mini2440, I have nothing showed up in the LCD! What can be the problem? This is what I'm using: #elif defined(LCD_LG12) #define LCD_PIXCLOCK 2 #define LCD_RIGHT_MARGIN 105 #define LCD_LEFT_MARGIN 88 #define LCD_HSYNC_LEN 31 #define LCD_UPPER_MARGIN 21 #define LCD_LOWER_MARGIN 4 #define LCD_VSYNC_LEN 1 BUT, I'm not sure of what value I should use for LCD_PIXCLOCK, and if I have to have some other considerations fot the total vertical and horizontal periods. Thank you all, Fernando
hi fernando try these settnings. even add these settings for nboot also #elif defined(LCD_LG12) #define LCD_PIXCLOCK 5 #define LCD_RIGHT_MARGIN 79 #define LCD_LEFT_MARGIN 119 #define LCD_HSYNC_LEN 12 #define LCD_UPPER_MARGIN 21 #define LCD_LOWER_MARGIN 4 #define LCD_VSYNC_LEN 1
Dear all, Hi I used the LCD- s7 in my main-board and every thing ok for these, but when i use the LCD- A7 the touch of LCD is not calibrated. Please help me. Best wishes Jak
