Download & Run not working
nils
I'm trying to run the 2440test code *without* switching the NAND/NOR switch
everytime and want to use the Download & Run function from the bootloader,
but it isn't working.
If i use it, download the code with DNW the board freezes.
Does anyone know how to do this?
Yoav
You have to configure the USB transfer option to use the address
0x30000000. This is the SDRAM address. The default is 0xC000000 - which is
the NAND address and obviously not working with the 'Download & run"
option.
The option 'd' that you have chosen is used for uploading images to the
SDRAM and then automatically running from location 0x30000000.
