HI im tring to build an application for my mini2440 im following the instrution of: http://www.sereno-online.com/site/2010/05/01/qt-4-6-2-installation-proce... but when i put the command: ./configure -embedded arm -xplatform qws/linux-arm-g++ -prefix =/usr/local/Qt -qt-mouse-tslib -little-endian -no-webkit -no-qt3support \ -no-cups -no-largefile -optimized-qmake -no-openssl -nomake tools appears me this mistake: The tslib functionality test failed! You might need to modify the include and library search paths by editing QMAKE_INCDIR and QMAKE_LIBDIR in /home/felipe/qt-mini/mkspecs/qws/linux-arm-g++. i saw a similar forum about this here : qtopia everywhere but it doesnt say how can i solve this problem. can anybody helpme?
qtopia on mini2440
HI i could fix the problem using this code: ./configure -embedded arm -xplatform qws/linux-arm-g++ -prefix \ /usr/local/Qt -little-endian -no-webkit -no-qt3support \ -no-cups -no-largefile -optimized-qmake -no-openssl -nomake tools but when i put make command appears me this mistake: make[1]: arm-none-linux-gnueabi: No se encontró el programa make[1]: *** [../../lib/libQtCore.so.4.6.2] Error 127 make[1]: se sale del directorio `/home/felipe/qt-mini/src/corelib' make: *** [sub-corelib-make_default-ordered] Error 2 can anybody help me ? thanks
hi i found a solution QMAKE_LINK = arm-none-linux-gnueabi-g++ i had and space between - and g++ QMAKE_LINK = arm-none-linux-gnueabi- g++ but now appearsme this: .obj/release-shared-emb-arm/qtconcurrentiteratekernel.o: In function `getticks()': qtconcurrentiteratekernel.cpp:(.text+0x278): undefined reference to `clock_gettime' collect2: ld returned 1 exit status make[1]: *** [../../lib/libQtCore.so.4.6.2] Error 1 make[1]: se sale del directorio `/home/felipe/qt-mini/src/corelib' make: *** [sub-corelib-make_default-ordered] Error 2 grrr there is a mistake in every single step grrr what could be now?? help
Hi i could solve the problem i have to fix the file qmake.conf who its found on mkspecs/qws/linux-arm-g++ QMAKE_RANLIB = arm-none-linux-gnueabi –ranlib QMAKE_RANLIB = arm-none-linux-gnueabi-ranlib the problem was this line: "–" i could compile well and it also went succesfull when i put make and make install commands. my problem now its that i dont understand this step: In order to run our ARM compiled applications we have to set following environment variables on the mini2440 board: export TSLIB_TSEVENTTYPE=INPUT export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_TSDEVICE=/usr/input/ts export TSLIB_CALIBFILE=/usr/etc/pointercal export TSLIB_CONFFILE=/usr/etc/ts.conf export TSLIB_PLUGINDIR=/usr/lib/ts export LD_LIBRARY_PATH=/usr/local/Qt/lib export QTDIR=/usr/local/Qt export QWS_MOUSE_PROTO=tslib:/usr/input/ts export QWS_DISPLAY=LinuxFB:mmWidth=310:mmHeight=190 Where do i have to put this lines?? and isnt it a problem that i dont use this command :"-qt-mouse-tslib" when i configure qt? i read that mini already has this librarie but i have the doubt
and other thing i install qt creator on my ubuntu machine how is it suppose that i compile my programs with the qmake i have create?? i tried following this steps: "In QtCreator just go to the options, add a new version of Qt. The qmake is available in /usr/local/Qt/bin/qmake" thats what i did but the program doesnt let me do the changes who can help me with this two simple doubts?? i know that many people already has done this. hellp!!!
Hello. I use another board than you do, (freescale i.mx51) but i enabled the touchscreen support yesterday. Check if the tslib binaries are present. The following commands should be able to run on your target (the board); ./ts_test ./ts_configure There are other binaries as well, but if these work, i assume you have compiled tslib correctly. The 'exports' lines, should be runned from the terminal on the board as well, they will be used as input for tslib. Run a line at a time. You can check that the variable is set by running: echo $TSLIB_TSEVENTTYPE (an example). The most important once are these; check your /dev/input to see alternatives for the input device. I used these two, but with ts0 instead of ts. Important that they refer to the same device. export TSLIB_TSDEVICE=/usr/input/ts export QWS_MOUSE_PROTO=tslib:/usr/input/ts After that run the following command; ./ts_configure I everything is correct, you should see crosshairs on the screen you should touch to calibrate. After this i could run QT-apps with touchscreen support. -almagest
I followed the same tutorial as David and I was able to build Qt for mini2440. I then transferred the Qt library to mini2440 at usr/local/Qt/lib. I changed the environment variables as instructed from the guide. I am able to compile apps for the mini2440 from my host. But when I run them on the mini2440, I get the following error: error while loading shared libraries: libQtGui.so.4: cannot open shared object file: no such file or directory Please help
Have you checked that libQtGui.so.4 is in usr/local/Qt/lib on the mini2440 and is the correct format? I will be interested in the outcome as this was as far as I got before giving up! Good luck, Dave
Hi Dave, There was some problem regarding the libraries. The Qt libraries are named as libQtXxx.so.4.x.x. The cross compiled Qt/lib directory contains symbolic links to libQtXxx.so.4. I use a USB stick to move files to the mini2440 and hence, the links are lost while copying and well, I didn't look what these links point to. So according to me, a better way out is to copy the Qt/lib directory to the memory stick and rename the library files from libQtXxx.so.4.x.x to libQtXxx.so.4. I have just spend two days with the board and well, I didn't notice that it has Qt-4.6.3 library installed in it. There was also an app in FriendlyArm pane called Qt-4.6.3 demo. It is actually an app launcher and has many Qt-4.6.3 apps in it. They all run fine. The library is located at /usr/local/Trolltech/QtEmbedded-4.6.3-arm/lib on the board. So I added /usr/local/Trolltech/QtEmbedded-4.6.3-arm/lib to LD_LIBRARY_PATH. I ran the mouse calibration program (the 4.6.2 one) and it didn't give me the shared library error. But I am getting "Transformation error: Driver not found. Aborted". Any clue? Thanks :)
hi, can some one give me the detail step wise installation process in linux for QT-4 to develop applications for mini2440.
http://billforums.station51.net/viewforum.php?f=8&sid=da7126ee36b846... There are heaps of tutorials around. Tell "us" which ones you have tried and get back with your errors and questions.
i tried as steps mention in URl.....and complete those ,but i am not aware of things further to do........ http://www.sereno-labs.com/qt-4-6-2-installation-procedure-for-friendlya...
So, you have everything installed and tried the hello examples and you now you want to know what to do next? Something that would focus your efforts is what application do you want to make? It really helps to have a project or idea to develop. Likewise, I have spent the last year or so learning how to do various tasks on this platform BUT would fall back to developing real applications on the 8bit platform I know so well. Of course there are many things I couldn't do on that platform, but until a BIG project says "develop me" on the ARM platform I will continue to just "play" with it. So, what do you want to do? Dave
hi i have installed qt 4.6.3 success fully.i have created a application hello with the following source .i get compiled but when i run application to my target board with ./hello -qws option it gets me error illegal instruction. #include <QApplication> #include <QLabel> int main(int argc, char*argv[]) { QApplication app(argc, argv); QLabel *label = new QLabel("Hello Qt!"); label->show(); return app.exec(); } [root@FriendlyARM /mnt]# ./hello -qws Illegal instruction
I don't have the Qt Designer on the CD which i got with my mini, therefore i can't make any apps for it. Can somebody mail me the download link for Qt Designer from Trolltech for qtopia 2.2.0 or post it as a download link in your blog. My mail id is tanushri.c [at] gmail [dot] com Regards Tan
I don't have the Qt Designer on the CD which i got with my mini, therefore i can't make any apps for it. Can somebody mail me the download link for Qt Designer from Trolltech for qtopia 2.2.0 or post it as a download link here. My mail id is tanushri.c [at] gmail [dot] com Regards Tan
.obj/release-shared-emb-arm/qtconcurrentiteratekernel.o: In function `getticks()': qtconcurrentiteratekernel.cpp:(.text+0x3c): undefined reference to `clock_gettime' collect2: ld returned 1 exit status gmake[1]: *** [../../lib/libQtCore.so.4.6.3] Error 1 gmake[1]: Leaving directory `/home/envirotech/Qt/arm-qte-4.6.3/qt-everywhere-opensource-src-4.6.3/src/coreli b' gmake: *** [sub-corelib-make_default-ordered] Error 2 How to solve this problem
I'd be checking to see that a qtconcurrentiteratekernel.h was being included by qmake or whatever is doing the linking. And have you got a qtconcurrentiteratekernel.h file in the source somewhere?
The tslib functionality test failed! You might need to modify the include and lib search path by editing QMAKE_INCDIR & QMAKE_LIBDIR inmkspec/qws/linux-arm-g++ This error generate in qt install for embedded arm
Thanks for your guidence in building of mini2440. But i faced some problems while configuring Qt by following command ./configure -embedded arm -xplatform qws/linux-arm-g++ -prefix /usr/local/Qt -qt-mouse-tslib -little-endian -no-webkit -no-qt3support -no-cups -no-largefile -optimized-qmake -no-openssl -nomake tools -qt-sql-sqlite -no-3dnow -system-zlib -qt-gif -qt-libtiff -qt-libpng -qt-libmng -qt-libjpeg -no-opengl -gtkstyle -no-openvg -no-xshape -no-xsync -no-xrandr -qt-freetype -qt-gfx-linuxfb -qt-kbd-tty -qt-kbd-linuxinput -qt-mouse-tslib -qt-mouse-linuxinput I got the following error…. project.o: could not read symbols: File in wrong format collect2: ld returned 1 exit status make: *** [/usr/local/qt-everywhere-opensource-src-4.6.3/bin/qmake] Error 1 please help me
Check out this tutorial: http://mini2440vietnam.blogspot.co.nz/2011/04/upgrade-qt462-in-mini2440.... Maybe it helps.
@Pavanbobba I had exactly the same problem to you. Add these QMAKE_INCDIR and QMAKE_LIBDIR like davef posted, but it did not solve the problem. Then, I added the QMAKE_LIBS = -lrt, the problem solved. There is error because we need real-time link for library. Hope to help you in your case.
@Pavanbobba Sorry for the last post, it was wrong, -lrt lib is for solving problem of the following error: undefined reference to `clock_gettime' - error 1 In your case, I also had this problem before. My problem is because of using x64 toolchain croos-compiler instead of x86 toolchain.
Guys I have a problem I have libQtGui.so.4 in usr/local/Qt/lib and I can run Qt demos without a problem but when I try to run my own program which was written in Qt I get this error in console: error while loading shared libraries: libQtGui.so.4: cannot open shared object file: No such file or directory It's pretty much weird considering all demos are running just fine. What do you think ?
@Mosi, add "export QTDIR=/usr/local/Qt export QWS_DISPLAY=LinuxFB:mmWidth=105:mmHeight=140" in /etc/profile (without Quotes"
