Is there any work being done to port Android to the Mini2440 ? -John G
Android ??
Android run on mini2440 (ARM 920T): http://www.youtube.com/watch?v=05aFF0fx4hs http://www.youtube.com/watch?v=EpB0gQXMPpY
I have seen those video's but I have not been able to find the images to load on my Mini2440... Are you aware of any links ??
There is a thread in the Japanese Android Group: http://groups.google.co.jp/group/android-embedded-japan/browse_thread/th...
Hi, http://devbored.com/?page_id=21 You can see an android distribution. Does anyone know how to make an image to download to the mini2440? Thanks Joaquim
Android is now available for the Mini2440 board: http://www.arm9.net/download.asp
anyone knows how to change the language in android to enlish?! I installed it sucessfully but i cant understand a thing!
Got me puzzled for a while what all those characters means, but changing the country/language and timezone in default.props in UK, UK and Europe/Amsterdam helped a lot!
I booted the board with serial console attached and modified the default.props on the root filesystem using vi.
I have downloaded the Android image (from www.arm9.net) successfully to my Mini2440 board. But does anyone realize that the screen display is not perfect? It seems a bit shifted to the right, and there's also a significant portion of the right edge of the screen that is not displayed (shouldn't there be an AM/PM after the time?) I've googled images of successfull android ports on mini2440, most of the shows the correct display, unlike the image that is shown on www.arm9.net/download.asp (the pdf manual file). Does anyone here knows how to get a working android image for the 128MB mini2440??
I also bought this board from http://www.mini-box.com/Samsung-S3C2440A-400MHz and I want to port Android on in. I'm looking for an english manual, or some tools to translate the japanese one. Thank you
You can use Google Translator for translating the Chinese manuals: http://translate.google.com
If your image is shifted, you have the NEC 3.5" LCD and the newer Mini2440's have a Toppoly LCD with different timing. It needs a different compilation or boot parameters. There will be a "Mini2440 Survival Kit" on http://www.andhammer.com in a few days.
I just recently upgraded to the new 128M board. I have followed the instruction to the T but I cannot get the board to boot. Below is what happens: Copy linux kernel from 0x00060000 to 0x30008000, size = 0x00200000 ... done zImage magic = 0x016f2818 Setup linux parameters at 0x30000100 linux command line is: "noninitrd root=/dev/mtdblock2 init=/init console=ttySAC0 ,115200" MACH_TYPE = 1999 NOW, Booting Linux...... I get that far and it stops working. Does anyone know what to do. Thanks, DANtheMAN
Irfan, seems that you got a "china" mini2440 version. This version that you got DOES not came with a NEC LCD, it cames with a "Toshiba" LCD. The android image that you have downloaded (adamhammer) were compiled to run on the NEC LCD. My china board works exactly as you described. Right now I'm installing linux on a new mobo to recompile this distro. Anyone here already recompiled it to run on a T35 LCD?
There's some compiled binaries and stuff here:- http://www.developmentboard.net/index.php/productdetail/Development+boar... ... not sure if that's helpful or not though. The .zip file on their web site is actually a .zip.gz file, FWIW.
I am using micro2440 and i want install android os on my board but i see this problem : failed to get memory region resouce s3c2410-iis: probe of s3c2410-iis.0 failed with error -2 TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. s3c2410-rtc s3c2410-rtc: setting system clock to 2010-02-14 23:03:34 UTC (1266188614) yaffs: dev is 32505858 name is "mtdblock2" yaffs: passed flags "" yaffs: Attempting MTD mount on 31.2, "mtdblock2" yaffs: auto selecting yaffs2 yaffs_read_super: isCheckpointed 0 VFS: Mounted root (yaffs filesystem). Freeing init memory: 116K Warning: unable to open an initial console. how to fix it ? thanks a lot.
Reply to Vuska: go to your android rootfs output (uncompressed) find the 'dev' directory and create the the console entry with: 'mknod console c 5 1' (you may need to append sudo) that should solve that problem.
Give Google Translate a try http://translate.google.com/
George, i wouldn't have had problems with translation since have had a guide itself:) Please, where can i download the Android guide on Micro2440 with 7' screen? Thanks
I have complete step-by-step instructions, including all of the necessary files, for installing the Android OS on a mini-2440 in under an hour. The resulting configuration boots and runs from a SD card. This really simplifies customization and troubleshooting! The instructions are at my website: http://mini2440.spaceopera.org/site/developmentenviroment/stepbystep/ind... Shannon haworth
I have manage to compile android 1.5 with Freeunners toolchain, and boot it on micro2440. Needed a fake battery driver for the kernel, and some Java hack in the framework files. I used the linux kerel from FriendlyARM. If anyone i interested i further details I'm happy to answer questions.
So two of you got Android 1.5 working on mini2440 .... good news. There are 3-4 questions from me: 1. How about the performance of Android 1.5? Is it slow or fast? 2. Has anybody Android 1.5 running with the 7" Display? Perhaps one ot the two guys running Android 1.5 uses a 7" Display for it? 3. How about getting wlan working in Android, possible? 4. And last but not least, can somebody of you two guys share your android image+kernel file with us??? Would be nice if u could answer my questions, because i see only two practicle OS for the mini2440 .... First is the qtopia-image with qt 4.6 and the second is android. Qtopia seems to work nice, but you need to crosscompile if u want to develop apps for it. Developing for Android would be much easier.
Hi, I was curios to know the version of Android available in the download section of this site. Regards, Vikas
the Android-Version in the download-Section on this site (and on the chinese-site too) is only 0.9 ... crap. That's the reason why i am interested to get a android-image from the two guys above, they managed android 1.5 to work on mini2440
Hi, I have some issues with the touchscreen, cant get it to work yet. but i working on it. About the performance i cant see anydiffrence from the Android version FriendlyARM has. I got Wlan working on FriendlyARMs Android version except the Settings apps. But i could surf the web from the browser, setting up Wlan from the kernel. Its my goal to get wlan work with my 1.5 version ,but first i need to get touchscreen working. And I using 3.5" screen and friendlyARMs wifi-module. I dont have any good way of sharing files ower internet. anyone know a good site for doing that I can put my FS and Kernel there.
I have uploaded the Kernel @ Rapidshare. http://rapidshare.com/files/372551485/kernel.tar.gz.html The kernel i basicly the same as Friendlyarms Android kernel but with drivers for wifi and fake battery. The filesystem is to large for rapidshare (4.6G).
Got the touchscreen to work today. The problem was that the kernel was missing the powermanagement drivers for android. Wich made android stay in locked state and didnt take any input from the touchscreen or buttons. Whit the drivers included in the kernel everything worked just fine.
hi ... i don know if u r still seeing this page any more...but i managed to run android on mini2440 but it is 64 nand wityh nec3.5'' (on sd card).....but i cannot control it as there is some problem with the back button is not viewed i think that there might be some problem with compatability with lcd... should i re configure the kernel or what ... has the file system any effect .... what is the difference bet. a file system for 128 or 64 nand....or its only the kernel???? if any one could give me a good kernel(uImage)...or tell me what to do please
@ Optimum i had the same problem as Vuska and i do like you say with the console. But after that i get the following error: s3c2410-rtc s3c2410-rtc: setting system clock to 2115-02-05 12:22:00 UTC (283845224) Waiting 3sec before mounting root device... kjournald starting. Commit interval 5 seconds EXT3 FS on mmcblk0p3, internal journal EXT3-fs: mounted filesystem with ordered data mode. VFS: Mounted root (ext3 filesystem). Freeing init memory: 116K open file errer! xres = 240, yres = 320 does it something to do with the console or is this another error and how can i solve it? Thanks in advance Blackman
dear Henrik Alexandersson , congratuation for working your mini but i have a request? i need to make my mini work with wifi so i download the kernel you upload and for filesystem is it have changes from friendlyarm ? if yes could you tell me what is the differences to try to make it or please upload it try to use http://www.megaupload.com/ to upload thanks in advance
I got to the command line by changing setenv bootargs console=ttySAC0,115200 root=/dev/mmcblk0p3 rootfstype=ext3 mini2440=1tb rootdelay=3 init=/linuxrc to setenv bootargs console=ttySAC0,115200 root=/dev/mmcblk0p3 rootfstype=ext3 mini2440=1tb rootdelay=3 init=/system/bin/init So, there is some problem with the linuxrc script which is causing the system to stop booting. It is the /bin/ts line which is causing the problem.
anyone have the image of android for S3C2440 256M for the X35? I do not, and do not know where to find the driver for the X35, and I do not know where to put the driver in the kernel menuconfig, someone please help me? thanks,
Hi Vitor Christo. First, you have to find out X35 driver, then put it into /your-directory/android/kernel/include/config/fb/s3c2410/ (where has only t240320.h there) before cross-compile kernel for android. Then, you go to "make menuconfig", choose "Device Drivers" -> "Graphics support" -> "Support for frame buffer devices"-> "LCD select". If you already coppied X35 driver on above step, X35 should be appeared then.
oh, sorry, it seems my fault. Above advices aren't true at all, sorry. To solve X35, visit here http://www.friendlyarm.net/forum/topic/2016?lang=de
Hi again. I've cross-compiled zImage for Android of X35 mini2440 board. http://www.mediafire.com/?d4f45usa5x0k9b5 Try that. Good luck
@whitebank oh man, you did it! It is working! I have mini2440 with FriendlyARM X35 version touchscreen and had no luck in running android on it until I tried your zImage! To be precise, I changed it to uImage on Ubuntu with command: mkimage -A arm -O linux -T kernel -C none -a 30008000 -e 30008000 -n "./zImage" -d zImage uImage I see everything on LCD now but have to adjust touchscreen... I mean when I ie. try to move Clock on screen to the upper right - it goes opposite way... But nevertheless it IS WORKING :)
Hello, I also edit zImage with W35 screen, please prefer to http://mini2440vietnam.blogspot.com/2011/05/install-android-for-mini2440...
