I have downloaded Android from the friendly arm website, and was able to compile and install it on my mini2440. However now I would like to get Android Debugger Bridge working for it. My understanding is that it is that the USB Gadget "Android Gadget" provides the boardside driver for this (through which the debugger daemon operates). So I install this and "Switch" driver into the kernel. However there is a catastrophic exception in the kernel as soon as I plug the board into a PC via the USB device port (seems to happen somewhere in a USB interrupt handler). Has anyone actually gotten "Android Gadget" to work? Or the ADB interface in general?!?!
Hi I have the same problem. I install the Android in micro 2440 sdk board but I want to debug it with the Eclipse and Android SDK via USB, but when I run Android and connect the board to PC, it doesn't destect nothing. Thanks
I am having the same problem. With Android running on the device, connecting it to the PC via USB, nothing happens. It seems that the PC does not even detect that a USB device has been attached to it. Please Help. Thanks
