Hello! I'm trying to make network work on Mini2440. I've tried UDHCPC but there is an error: "udhcpc (v1.13.3) started udhcpc: exec /usr/share/udhcpc/default.script: No such file or directory udhcpc: socket: Address family not supported by protocol" I've tried to add DHCP to Kernel but nothing has changed. I have always the same IP (192.168.1.230) and mask (255.255.255.0). How can I fix it? Is there any other way then configuring it manually? thanks in advance best regards Tomasz
configuring network (DHCP)
Also you need to configure your network interface in /etc/networking/interfaces for using dynamic ip address assigned by dhcp server.
I'm using "Linux FriendlyARM" and don't have "/etc/networking/interfaces". I've found only "/etc/eth0-setting". Tried tu ose udhcpd but nothing happend. thanks in advance best regards Tomasz
yes the same problem is with me too . I also don't find the path /etc/networking/interfaces in my mini2440 and instead of that I have /etc/eth0-settings. So tom please tell me how to get the solution to it. Actually I have the kernel and rootfs image installed from the andahammer.com site Thank u
Dear All Trouble Shooters, I am impressed with the kind of path you have shown to Embsys. I have successfully installed PPP on mini2440 and connected to PPP server and thus internet. But when I run openvpn over ppp-network iam getting the following error, TLS negotiation failed to occure within 60 secs (check network connectivity) But, I am able to establish connection between openvpn server and client with normal TCP/IP connection. Can any one help me in this regard. With Best Regards, Nikhil N.D.
Hello jey How can I configure a text system file with putty in serial mod communication “Nano” didn’t work in my board
