i manualy do a partition to a mini2440 - 64 an downloa all the files OK when i boot it , the screen start to flash and in the DNW i get this message Linux...Uncompressing Linux...load Image of Linux...Uncompressing Linux...load Image of Linux...load Image of Linux...Uncompressing Linux...load Image of Linux...Uncompressing Linux...load Image of Linux...Uncompressing Linux...load Image of Linux...Uncompressing Linux...load Image of Linux...Uncompressing Linux...load Image of Linux...Uncompressing Linux...load Image of Linux...load Image of Linux...load Image of Linux...Uncompressing Linux...load Image of Linux...Uncompressing Linux...load Image of Linux...Uncompressing Linux...load Image of Linux...Uncompressing Linux...load Image of forever ............................... also the 4 leds inside flash at the same time if i unplug the screen the leds flash and i get the same message in DNW i dont understand whats going on ? saludos arc.
screen flashing
hey, try an other PSU. i had the same thing when i used an lab PSU with too thin cables (not enough amps that could flow through with croc clambs) other wise, check the PSU connector, it's a little bit larger than the standard plugs that you can order. other words, order the PSU from the site. Best regards! Willem
