hello all i have 1 week the new mini2440v2 board with 3.5 screen with the preload version of qt i can get the Gui screen running if i upload the OE version x11 or xorg or opie to the mini2440 i cnot get the xserver runing i get black screen all the time and i get console login in i compile the rootfs from OE and from angstrom website with x11 server and all have the same problems i try debian with x11 and its dont show me the gui. any one have last rootfs with xserver runing or opie ? from the last git ? Thanks
X server xorg
I have to agree that it is difficult to get Xorg server running. There are so many options. Are you sure you configured it for framebuffer device (fbdev)? I got it running and I was able to start IceWM with touchscreen :) And I had half of RAM left (approx. 30MB).
Hello Jay, you said you could run Ice with 30MB left, can you tell us some directions on doing this? When i try to run it, i have only 2mb left... can you give us some manner to do this ? Really thanks in advance
I'm trying to get Xorg server running to and have same problem. Jay could you please paste here your xorg.conf file?
this the error iget for x server i test (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jun 30 11:40:43 2010 (==) Using config file: "/etc/X11/xorg.conf" (EE) Failed to load module "glx" (module does not exist, 0) (EE) Failed to load module "dri" (module does not exist, 0) (EE) FBDEV(0): FBIOPUT_VSCREENINFO: Invalid argument (EE) FBDEV(0): mode initialization failed Fatal server error: AddScreen/ScreenInit failed for driver 0 -- And this is the xorg.conf Section "Monitor" Identifier "Monitor0" ModelName "Monitor Model" DisplaySize 240 320 EndSection Section "Device" #Option "ShadowFB" "true" Identifier "Card0" Driver "fbdev" Option "fbdev" "/dev/fb0" EndSection Section "Screen" Identifier "Screen0" Device "Card0" Monitor "Monitor0" EndSection and this is the xorg.conf
I am sorry but I havn't made a backup of the configuration files before I reinstalled debian. This tutorial has worked for me: http://project4fun.com/node/5
Also it depends on the kernel how optimized it is for using low ressources. It could be that a bad configured kernel is using the whole RAM space if you try to start the X server so you arn't able to do much with it. I was able to start VLC as internet radio streaming client. The touchscreen has worked fine but I needed to do some manual configuration and calibration to get it working (I have had the problem that the directions were wrong so if you tried to move the cursor up, it has moved down - but there were some options in xorg.conf to get it working).
Hello Jay, really thanks for you answer! Well my friend, i used all steps in projects4fun but even making all steps they provided my mem was really low on running xserver... Even without any window manager (just the X) my resource went down... And yes... i also had this terrible calibration problem! lol! Did you make any changes in kernel for making X works consuming less memory? ( I tryed everything in xorg.conf and nothing makes 30mb free) Can you give us some directions on how to do this? Some tips on configuring the kernel for this kind of optimization? This info will save my life and job! lol! Really thanks in advance
Would you like to try it with my kernel? It's on http://git.programmers-projects.de/index?p=mini2440-dev.git;a=tree. But I am not sure if it lets you enough RAM because I have changed many things in the configuration in the last time. Without X it takes around 10 MB of RAM. It's a long time ago as I ran X successfully.
Hello !!! Can somebody explain briefly or give some resource on how to build XOrg for ARM? I tried to do it by myself, however I don't have experience with XOrg and I don't know the sequence etc ... I tried to build xorg-server , but I got some errors concerning some libraries that were not found ... Please please help me to resolv this. Many thanks
It's available as debian package for armel processors. I can't say much about other distributions because I only need debian so I can install it via apt-get install xserver-xorg-video-fbdev directly on mini2440 with working network connection.
Can any one have a working X on the mini2440 if so please can you send us a xorg.conf and more information
@Artem Park i did creating an "angstrom package with console interface" from http://www.angstrom-distribution.org/narcissus/ to use X i add this package xf86-input-evdev xf86-video-fbdev xserver-xorg xserver-xorg-extension-glx xserver-xorg-extension-dri xserver-xorg-extension-dri2 gtk+ after that, i can run my' graphical application' built on gtk. this is the way i did it from "console package". ============================= opkg update opkg install xf86-input-evdev xf86-video-fbdev xserver-xorg xserver-xorg-extension-glx xserver-xorg-extension-dri xserver-xorg-extension-dri2 gtk+ libxml2 mkfs-jffs2 ============================= to use this X, i did this ============================= export DISPLAY=:0.0 X :0.0 -nocursor & ./my_app ============================= @alex it worked fine with mine, and i had backuped this root as jffs2 image with size in 22MB. And i got none in my /etc/X11/xorg.conf. And yes, those mkfs-jffs2 package i used to backup this root, and i got failed twice uploading my root image to www.mediafire.com, sigh.. GUTLAK GAN (^_^)7
X server can be builded with Buildroot. There can be compiled Xfbdev, which works fast on this platform.
