Hi all, I am trying for android porting on mini2440.i have all the necessary images required for this but i need to add some functionalities and API's into android for mini2440 so images are not going to work for it. so i need any kind of help regarding where can i get android code base for mini2440 board or any patch if there is? thanks in advance regards dayal
Android code base for MINI2440
Hi Andreas, Thanks for your quick reply..but i can't see any code base there for direct download..will you please tell me how to fetch full code base from your given link because downloading git directly doesn't provides total code (like bionic, framework, are not there). is there something else what i have to follow other than direct downloading of git?
ohh i got the way.. i was wrong and using git clone to download source code and because of that i was getting just a manifest file. actually it's repo init and then repo sync.now i have android code base for mini2440. thanks andreas. regards dayal
Hi dayal, I don't understand how to download code base from the link. Can you please explain me the same. Thanks & Regards, satish
You can try this: curl http://android.git.kernel.org/repo >~/bin/repo chmod +x ~/bin/repo repo init -u git://gitorious.org/android-mini2440/manifest.git -b cupcake repo sync
