TSLIB calibration not working?
t11s
Out of the box, my FriendlyARM boots up into Qtopia, then it  says:
"TSLIB Calibration utility
Touch crosshair to calibrate"
But I touch the crosshair with the stylus, and nothing happens.  What am I
doing wrong?
So, when you touch the centre of the crosshair in the top left corner (with
the stylus) it does NOT move to the top right corner?
t11s
Yes, that is correct, absolutely no response, movement, or anything.
Jason
Check all cables and connectors.
Asier
Hi t11s.
I'm at the same point. Did you get to pass the calibration? All my cables
seem to be ok.
Thanks for the help!
Asier
I've installed Windows and run it, but the screen touches are not being
detected. Am I missing anything or there is something wrong in my hardware?
saurav
all things happens but the screen dowsnt works
ts_test
What do you see?
KimW
I get to this same point, if I display the events "cat /dev/input/event0" I
can see that there is a response to the touch screen but the cross hairs
don't indicate any response.
I haven't found a ts_test command as of yet.
I am using a micro2440 with a 7" screen and the standard linux
installation.
Thanks for any help.
standard Linux = 2.6.32.2 from FriendlyArm AND it is been built for the A70
touchscreen?
Command line works normally?
Check the other entries in /dev/input
KimW
Everything appeared to be working correctly.  I'm able to serve pages and
view them on the network.  The boot looks fine and doesn't thrown any
outrageous errors.
On further inspection it looks like the touchscreen ribbon cable may be
damaged and may be causing the issue.  I'll look into that next.  I assume
that means needing to replace the screen and cable as they come as a unit.
Hadi kadhim
TSLIB calibration utility touch crosshair to calibrate
