Hi All
Regarding NFS File system
eth0: link down
IP-Config: Guessing netmask 255.255.255.0
IP-Config: Complete:
device=eth0, addr=192.168.1.0, mask=255.255.255.0, gw=255.255.255.255,
host=192.168.1.0, domain=, nis-domain=(none),
bootserver=255.255.255.255, rootserver=192.168.1.1, rootpath=
Looking up port of RPC 100003/2 on 192.168.1.1
eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
rpcbind: server 192.168.1.1 not responding, timed out
Root-NFS: Unable to get nfsd port number from server, using default
Looking up port of RPC 100005/1 on 192.168.1.1
Root-NFS: Unable to get mountd port number from server, using default
Root-NFS: Server returned error -5 while mounting /export/fs
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Cannot open root device "nfs" or unknown-block(2,0)
Please append a correct "root=" boot option; here are the available
partitions:
1f00 384 mtdblock0 (driver?)
1f01 2048 mtdblock1 (driver?)
1f02 128640 mtdblock2 (driver?)
1f03 131072 mtdblock3 (driver?)
b300 1931264 mmcblk0 driver: mmcblk
b301 203616 mmcblk0p1
b302 203616 mmcblk0p2
unknown-block(2,0)
could you please suggest me,to solve this problem.
Giving your eth0 an IP od xxx.xxx.xxx.0 is a bad idea. This IP (in
conjunction with the above netmask) is reserved for a net, not an
individual member of the net. Better use something in the range .1 ...
.254 (and take care that it doesn't collide with other members of the net,
i.e. the chosen IP must be unique on your net).
This may be or may be not a consequence of the above error. Correct it,
and if the error message persists, check that there is indeed an NFS server
on 192.168.1.1 listening and your mini2440's IP is there allowed to access
it ("man exports" will be of help for the latter one). If all is well up
to this point, check the server's logfile.
Thnks for reply device=eth0, addr=192.168.1.25, mask=255.255.255.0 where we can find server's logfile.
> where we can find server's logfile. Erm ... that depends on the operating system the server is running. If it is Linux, have a looh into the directory /var/log.
I have a problem just like your's http://www.friendlyarm.net/forum/topic/3049 I can even ping the qemu's virtual net card(not the tap0 ip,but the 2440's ) can duraisamy tell us how to disable firewall?
Hi In Ubuntu, you can disable firewall by this: $sudo ufw disable You can link to here for more information connected by NFS http://mini2440vietnam.blogspot.com/2012/05/share-files-with-nfs.html
Hi, guys..
Regarding NFS fs
eth0: link down
device=eth0, addr=192.168.1.6, mask=255.255.255.0, gw=255.255.255.255,
host=192.168.1.6, domain=, nis-domain=(none),
bootserver=255.255.255.255, rootserver=192.168.1.5, rootpath=
Looking up port of RPC 100003/2 on 192.168.1.5
rpcbind: server 192.168.1.5 not responding, timed out
Looking up port of RPC 100005/1 on 192.168.1.5
partitions:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown
block(2,0)
Please help...fixing the problem....
I had a similar problem with my mini2440 using fedora 14 I may have had several problems i was using virtualbox first make sure that your eth0 is actually the physical Ethernet port(settings->Network in adapter 1 select bridged adapter, Ethernet controller(mine was Realtek PCIe GBE Family Controller) you can probably use NAT but i wanted to be able to get on the internet as well make sure cable connected is checked. this is extra if you are using a usb to serial goto settings->USB and add the usb device this will automatically enable it each time the vm starts. connect your device to your computer(it must be powered) type ifconfig eth0 should be whatever ip address you assigned to eth0 for my example eth0 should have been 192.168.1.27 i changed it using GUI System->Admin->Network edit eth0 statically seet ip 192.168.1.27 netmask 255.255.255.0 default gateway 192.168.1.1 but for some reason eth0 was not changing so i manually changed it using command line in terminal(ifconfig 192.168.1.27 netmask 255.255.255.0 as disabled the firewall service iptables save, service iptable stop, chkconfig iptables off) then it worked.
Hmmm... looks like the portmapper daemon of NFS server isn't responding.
The portmapper daemon is responsible for exposing the ports on which the
other NFS daemons (nfsd, mountd, statd etc.) listen.
Use 'rpcinfo -p' command to check status of all RPC utility programs on the
server.
HTH,
Gautam
I am Having the same problem as shown above. below is the log for
"rpcinfo -p". What can i do now...?
/mini2440/u-boot/u-boot_20100701$ rpcinfo -p
program vers proto port service
100000 4 tcp 111 portmapper
100000 3 tcp 111 portmapper
100000 2 tcp 111 portmapper
100000 4 udp 111 portmapper
100000 3 udp 111 portmapper
100000 2 udp 111 portmapper
100024 1 udp 48161 status
100024 1 tcp 51204 status
100003 2 tcp 2049 nfs
100003 3 tcp 2049 nfs
100003 4 tcp 2049 nfs
100227 2 tcp 2049
100227 3 tcp 2049
100003 2 udp 2049 nfs
100003 3 udp 2049 nfs
100003 4 udp 2049 nfs
100227 2 udp 2049
100227 3 udp 2049
100021 1 udp 52670 nlockmgr
100021 3 udp 52670 nlockmgr
100021 4 udp 52670 nlockmgr
100021 1 tcp 53778 nlockmgr
100021 3 tcp 53778 nlockmgr
100021 4 tcp 53778 nlockmgr
100005 1 udp 40120 mountd
100005 1 tcp 52715 mountd
100005 2 udp 37540 mountd
100005 2 tcp 48922 mountd
100005 3 udp 53744 mountd
100005 3 tcp 35378 mountd
This is almost aways the linux internal firewall. Mark the port as trusted then incoming requests for NFS helper functions can get through
