HI at least i can start with this cross compile (the previos topic was
about libxml who its necessary for php)
i started with this code:
export CROSS_COMPILE=arm-none-linux-gnueabi-
export CC=${CROSS_COMPILE}"gcc"
export CXX=${CROSS_COMPILE}"g++"
./configure --host=arm-linux --target=arm --with-libxml-dir=/opt/libxml
--prefix=/opt/php
but when i put
make
at the end it throws me this mistake:
cc1: warning: include location "/usr/include" is unsafe for
cross-compilation
/home/felipe/Escritorio/php-5.3.1/ext/standard/basic_functions.c: In
function 'zif_getservbyport':
/home/felipe/Escritorio/php-5.3.1/ext/standard/basic_functions.c:5589:
error: invalid 'asm': invalid operand for code 'w'
make: *** [ext/standard/basic_functions.lo] Error 1
any ideas???
starting with php cross compile
hi i change some lines:
Code:
./configure --host=arm-linux --target=arm --prefix=/opt/php \
--disable-short-tags \
--without-mysql --without-pear --disable-all --disable-short-tags \
--enable-libxml \
but now it is throw me this mistake:
/home/felipe/Escritorio/php-5.3.1/main/php_ini.c:349: undefined reference
to `php_load_extension'
collect2: ld returned 1 exit status
make: *** [sapi/cgi/php-cgi] Error 1
i feel like i am advancing but too slow grrr
i got the solution!!! change php-5.3.1 for previus version: PHP-5.2.10 NOW i can start to test on mini!!! i have a doubt at the end it throws me this: Build complete. Don't forget to run 'make test'. how can i make this make test??
grr i put make test and it throws me this: felipe@felipe-desktop:~/Escritorio/php-5.2.10$ make test Build complete. Don't forget to run 'make test'. /home/felipe/Escritorio/php-5.2.10/sapi/cli/php: 1: Syntax error: word unexpected (expecting ")") make: [test] Error 2 (no tiene efecto) did i made a bad compilation? =(
hi i configured my web server on my target device but when i test a .php file appears me this: 503 service unavailable i have a doubt do i have to put to run the php.exe file on my target device? i tried to do it but it throws me this mistake: eroor while loading shared librares_ libxml2.so2 i m tring to copy that file on my usb but i cant i think that the reason is why this libxml2 is a symbolic link, but then... how can i solve this problem? HELPPPPPPP! I M VERY CLOSE TO FINISH, PLEASE !!
hi i solve that problem copying that file on /opt/libxml/lib on mini 2440 but now throwme this mistake: error while loading shared libraries: libz.so.1, at this point i dont really know if i am get advance and i dont know if making this, the program will run =( help please,
hi i modified the code:
./configure --host=arm-linux --target=arm --prefix=/opt/php1 \
--disable-short-tags --disable-shared \
--enable-libxml \
--with-libxml-dir=/opt/libxml \
--with-zlib-dir=/opt/zlib
and send libz.so.1 to /opt/zlib of my mini2440
but when i put ./php appearsme illegal instrution, i dont what do now,
PLEASE HELP!!!
i didnt fix the problem =( Holly im working with: php-5.2.10 zlib-1.1.4 libxml2-2.6.19 if maybe you want to try it. thanks for the help!
remember that you have to compile first zlib and libxml2 following the steps i did on the php previus forum
hi i could put to work php on cherokee webserver on my embedd system it
seems that i have a bad cross compile of php this was my last use code:
export CROSS_COMPILE=arm-linux-
--disable-shared --disable-xml disable-libxml --disable-dom
--disable-simplexml --disable-short-tags \
--disable-xmlreader --disable-xmlwriter \
--without-mysql --without-pear --without-iconv --disable-all \
--enable-fastcgi
the lines that i had to added to my cherokee.conf file was:
vserver!1!rule!6!disabled = 0
vserver!1!rule!6!encoder!deflate = 0
vserver!1!rule!6!encoder!gzip = 1
vserver!1!rule!6!handler = fcgi
vserver!1!rule!6!handler!balancer = round_robin
vserver!1!rule!6!handler!balancer!source!1 = 1
vserver!1!rule!6!handler!change_user = 0
vserver!1!rule!6!handler!check_file = 1
vserver!1!rule!6!handler!error_handler = 1
vserver!1!rule!6!handler!pass_req_headers = 1
vserver!1!rule!6!handler!xsendfile = 0
vserver!1!rule!6!match = extensions
vserver!1!rule!6!match!extensions = php
vserver!1!rule!6!only_secure = 0
vserver!1!rule!6!match!final = 1
vserver!1!rule!6!timeout = 30
source!1!env!PHP_FCGI_CHILDREN = 5
source!1!env!PHP_FCGI_MAX_REQUESTS = 490
source!1!env_inherited = 0
source!1!host = 127.0.0.1:47990
source!1!interpreter = /home/php/bin/php-cgi -b 127.0.0.1:47990
source!1!nick = PHP Interpreter
source!1!type = interpreter
i hope that this experiences can be useful for some else.
but my final doubt its
i had to disable libxml and libz how can this affect the php's work?? i
have that doubt according to that i should try to fix my cross compile
Most likely need to recompile libxml and libz with CROSS_COMPILE=arm-linux- Show your cross compile options for libraries
HOlly i think that you most be right, when i compile those libraries it created me files of type " Link to shared library" could be this the problem?? and the only way i could send this files to my device was compressing them
Hi again i tested my php on my mini2440 first i made a simple test echo"hola mundo"; and it goes well after that i made a formulary and test it on my host machine, there it worked well, but when i tested on my mini2440 it didnt, soo i think i have to compile this php again grr, i think that the problem should be the libraries but .. could be the problem what i said above? thanks for the help!!
Why are you compressing the files before sending to the mini2440? Sounds like that could be an added complication. I haven't tried using that method. What size mini2440 do you have? Have you got Cherokee on there as well?
because when i tried to copy that files to my USB it throws me this mistake: felipe@felipe-desktop:/opt$ cp -rf libxml /media/KRYXTYN@ cp: no se puede crear el enlace simbólico «/media/KRYXTYN@/libxml/lib/libxml2.so.2»: Operación no permitida cp: no se puede crear el enlace simbólico «/media/KRYXTYN@/libxml/lib/libxml2.so»: Operación no permitida translate: can not create the symbolic link «/media/KRYXTYN@/libxml/lib/libxml2.so.2»:Operation is not allowed that happened to me when i was trying to pasted the files of type " Link to shared library" But may be this it the problem the way of how i pasted this to my mini2440
davef i send that file to my mini2440 for the reason i told you above, and yes on mini i have cherokee web server and i have 122 mb of store on my mini. i hope to be clear this time. and holly you are right i could paste this file using your command, i going to tested, my file system hmm i have install linux on my mini2440, following the manual instrution version 128, im not sure if am i clear.. Thanks for the help
look if i put ./php without pasting this libraries it throwsme this mistake: ./php: error while loading shared libraries: libz.so.1 cannot open shared object file: no such file or directory so i pasted my libz crosscompile folder and i think that it fix that mistake, i believe that i have to copy only that file "libz.so.1" no my full folder zlib because i change the name of other file that it found on it and it seems not mistake about it. after this i put again ./php and it throws me: ./php: error ./php: error while loading shared libraries: libxml2.so.2 cannot open shared object file: no such file or directory so i paste my libxml cross compile folder to my mini and after this i put ./php now the mistake its illegal instruction.... so what do you think that could be the problem? libxml2.so.2 or libz.so.1 any suggest it going to be helpul thanks for all the advices im close!!! :)
i forgot this was how i compile these libraries:
libxml
./configure --host=arm-linux --target=arm --prefix=/opt/libxml1
zlib
CC=arm-linux-gcc \
./configure --prefix=/opt/zlib
CC=arm-linux-gcc \
LDSHARED="arm-linux-gcc -shared -Wl,-soname,libz.so.1" \
./configure --shared --prefix=/opt/zlib
maybe you can give me some advice with these i really dont understand very
well the last part of zlib compilation i use this link:
http://www.ailis.de/~k/index.php?url=archives/19-ARM-cross-compiling-how...
thanks!
HI again i found this on other forum:
Postby mbirrell » 22 Aug 2006 13:15
Hi Max,
Thanks for the reply.
Tried that and got the same error.
Could it be looking for a particular library version?
Seems that some of my symbolic links? don't have an absolute path eg:
libxml2.so.2 -> libxml2.so instead of: libxml2.so.2 -> /opt/lib/libxml2.so
I would suspect this is bad?
mbirrell
Newbie
Top
Postby max » 23 Aug 2006 19:28
Yes that is most probably a problem with your libraries versions. Also it
can be that you don't have the libs at all.
Have you checked the list of files in your /opt/lib folder? I've posted a
listing in the previous page of this thread. You should be able to check
that you have all the required libs and the correct versions (and sizes).
If you miss a library you can download it from
http://hamster.hd.free.fr/Autre/
And your symlinks seems to be ok: I've got the same conf in my /opt/lib
folder.
Top
It Works!
After downloading the lib files and putting them in /opt/lib everything
works.
There the solution was dowload this library what means that i am maybe
doing a bad cross compile of this library but how can i fix this problem?
HI again i compile my library libxml again and while it compiled i saw this
message:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,--rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to `/etc/ld.so.conf'
then should i compile php adding some lineas about this, i dont understand
very well, if so its how can be that add line...
hi again i had the doubt about simbolic links libraries so compile the
liibraries again with this command lines:
/*********zlib***************/
CC=arm-linux-gcc \
/*********libxml**************/
--disable-shared
/************php*********/
--disable-short-tags --enable-shared \
--enable-libxml \
--with-libxml-dir=/opt/libxml/ \
--with-zlib-dir=/opt/zlib/
with these little changes the compilation doesnt create me that simbolic
links libraries and the size of this file reduce alittle.
after that i pasted the php compile file to my mini2440 and i tested php
./php but it throws me the same mistake:
IILEGAL INSTRUCTION+
i dont even paste the libraries to my mini. remember that before this it
normally looked for the libraries first and after this it throws me this
mistake..
so im not very sure where could be my mistake could be what i copy above:
during execution
during linking
HELLLP!
i was compresing that files because if i send them normally to my usb appears me a mistake, but now i can send them bye a command, or with my last compile that i write above
PHP is already available for armel processors in the debian packages tree so you don't need to compile it at your own.
I install qt in host, and by cross compiling I got the exec file. while run that in mini2440 kit it says "illegal instruction". how to solve this.
Jay im going to use php with sqlite, but the only link available for that its broken, are you using php with sqlite?? what is the package you recommend me to dowload??
i have download some packages but i didnt found the php.exe on that. so i dont know how to configure my webserver
Which webserver youre using? Apache2 or lighttpd? I would recommend to use lighttpd because it's better in performance and is using less ressources on armel processor boards. There you can run PHP as CGI module. Why youre speaking about php.EXE (which is a Windows executable)? I thought you want use php under Linux because this thread is for cross-compiling php under Linux.
jay, yes im using linux, but when i made my php cross compilation it create me a file executable php. (i did a mistake when i said a file.exe)that file i cant find it on the packages that i dowloaded from debian. could you tell me what package did you choose? About the webserver, im using cherokee web server and i could configure it to use php bye this line: source!1!interpreter = /home/php/bin/php-cgi -b 127.0.0.1:47990 then my problem its that i didnt find that file on the packages i dowloaded but i would like to test lighttpd if it allows me to run php faster Jay thanks for your help!!
I don't know about cherokee web server but it doesn't seem to be a problem with the webserver but with the php-cgi script. Also: do you have e.g. dpkg to install or a tool to extract the .deb file that can be found on http://www.emdebian.org/grip/search.php?package=php5-cgi&arch=&d... ? If youre using a armel debian filesystem (in my opinion this is perfect for mini2440), you can use dpkg -i php5-cgi_<version> or apt-get install php5-cgi (if the internet connection is working on your mini2440). It will install at least the binary in /usr/bin/php5-cgi.
on my mini2440 i have install qtopia 2.2. .... that is what comes on the cd, i tried to install php with your commands: apt-get install and dpkg but both commands throws me this mistake: command not found. im going to try with your link's package, but i would like to know how did you install apt on mini, but i think that it could be on other forum, friend thanks a lot!
hi i downloaded the package and send it to my mini2440 it has two files who are type symbolic links but both are broken, does it could be a problem?? however i test a php web page and it doesnt work it shows me: 503 Service Unavailable i wanted to test the file php who is found on /usr/lib/cgi-bin folder of my php uncompress file then i put : ./php and it throws me: error while loading shared libraries: libz.so.1: cannot opoen shared object file: No such file or directory. i have already compile that library for my previus process so i paste it on /lib of mini and it fix the problem however i tested again: ./php now it throws me this mistake: error while loading sahred libraries: liboning.so.2: cannot open shared object file: No such file or directory. i dont have that library, where i can dowload it?? how many additional libraries do i have to dowload to make this work?? thanks for all your help this its making me crazy
I have to excuese i already see that package, forgive my last doubt, iam tired to try with this for that reason i dont see the obvius. i could solve this problem but now (this never finish!!) error while loading shared libraries libssl.so.0.9.8 i tried to download it but.. the link its broke!!! what can i do? where can i find it?
i believe that i have to use all the dependences packages of this program but i see that it more than 1 broken link, where can i download that packages??. jay thanks for all your help
Try to disable SSL (seems that php or the webserver tries to load the library for it) first. SSL on mini2440 makes no sense if youre not running any security risk applications/scripts. Also, I would strongly recommend to use debian with APT because it would solve all dependencies for you.
Question: why you need Qtopia? Seems that youre building a webserver. For that (or other server applications) you don't really need this (also it takes many ressources). I recommend to install emdebian for armel (there is a good description on the site): http://emdebian.org/
For fix "illegal instruction" change for all libs and php
arm-none-linux-gnueabi- -> arm-linux-
then recompile and reinstall all
Eample
--disable-shared
--enable-libxml \
Holly you are right!! it fix the illegal instrution problem, how ever i test a .php page and it toke to many time loading and when it finish it show me: Service Unavailable. did you test that code? i think that we have advance, we are more close now. thanks, what could be the other problem? Jay, im working on qtopia because it has touchscrean, does embedebian has too? about disable ssl, im not very sure because php work well but without include libxml. so i believe that it has a good configuration. Thanks for all your help. we almost finish!!! :)
HI again ejjeje, i change the code of php compilation now it reads again
pages php
--enable-libxml --enable-dom -enable-xmlreadear --enable-xmlwriter
--enable-fastcgi --enable-xml \
but it continue with the problem that i cant work with formularies when i
tested a simple formulary it returned to me the php code.
do i need another librarie?
hi at least i works!!! thanks to all people who help with this!! i only have to enable another thing on php script, thanks again!!
jajaj thanks alot im going to write it althought all people who wants this too can do it following this forum, while i write the tutorial :) i have a final goal with this. configure php with sqlite, im going to look some information and take some advance before write here.. thanks again to all people to help me with this
I have installed gcc and such for armel processors directly in the linux filesystem so I am able to compile it directly on and for the mini2440.
Id be very grateful if you could post more details on what files you used, or locations. I too am interested in getting a small web server with php running.
Thanks guys davef, Holly, Jay, Holly ... This reply chain was music to my ears. I am going to start the cross compilation of Apache or Light HTTPD or Cherokee with SQLITE , PHP for a proprietory ARM board. If anyone is planning to cross compile MySQL, PHP, LIGHT HTTPD for ARM can follow this link: http://tw.myblog.yahoo.com/stevegigijoe/article?mid=317 http://tw.myblog.yahoo.com/stevegigijoe/article?mid=316 David - you are awesome man. i appreciate your perseverance. Cheers
I have mini-httpd with SSL running on a Mini6410. If you have the FriendlyArm compiler installed all you need to do is edit the Makefile :- CC = arm-linux-gcc And if you want SSL uncomment where it says and make SSL_TREE = wherever you have uncompressed openssl to And it works very well!
