Hi all, I wrote a GPL image slideshow program for Mini 2440. I uploaded the source code on https://sourceforge.net/projects/qt4lab/files/ The purpose of the software is to use the Mini 2440 as a "Photo Frame". The executable depends on Qt 4.6.3 and uses JPG plugin. I tested it on Linux Kernel 2.6.29 and I think it should work also for Windows CE (thanks to Qt) You can see a YouTube example of this program here: http://www.youtube.com/watch?v=MA1bkipXxkI Have Fun! Paolo
Photo Frame software for Mini 2440 (GPL)
Hi all, I uploaded on http://sourceforge.net/projects/qt4lab/files/ the binaries of the Photo Frame software. File pf2440.zip, available on sourceforge, contains the necessary Qt shared libraries, the executable, the image plugins and a couple of example images. pf2440 runs under kernel 2.6.29 and requires Qt 4.6.2 Place all the image you want to see in the slide show in /images directory and then run Remember to export following environment vars: export TSLIB_TSEVENTTYPE=INPUT export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_TSDEVICE=/usr/input/ts export TSLIB_CALIBFILE=/usr/etc/pointercal export TSLIB_CONFFILE=/usr/etc/ts.conf export TSLIB_PLUGINDIR=/usr/lib/ts export LD_LIBRARY_PATH=/usr/local/Qt/lib export QTDIR=/usr/local/Qt export QWS_MOUSE_PROTO=tslib:/usr/input/ts export QWS_DISPLAY=LinuxFB:mmWidth=310:mmHeight=190 run ./pf2440 -qws -nomouse from a telnet session If you have any question or request please, leave a comment. Have Fun! Paolo
why export TSLIB_TSDEVICE=/usr/input/ts why not /dev/input/ts ? I have no Qt4 in my board, and can not run it. thanks mindee
@mindee together with the executable, I packed -in the zip file- all the Qt libraries, I think it should work on your Mini 2440. Concerning TSLIB_TSDEVICE=/usr/input/ts it seems I made a mistake writing the post... I made some test with /dev/input/event0 and it's ok. Thanks paolo
Hi Paolo Thank you for your posts. After configuring the QWS_DISPLAY with the command export QWS_DISPLAY=LinuxFB:mmWidth=310:mmHeight=190 (i have a 3" lcd) i run my application and i got a segmentation fault. if i comment export QWS_DISPLAY=LinuxFB:mmWidth=310:mmHeight=190 i can run my app but with out touch screen. I know that the tslib is installed becouse when i put a cat /dev/event0 i got some trash in the lcd. i´ve have installed already the tslib at my host computer and follow every step to configure it. I dont know what else to do. Please help me with some post to configure it. Thanks in advance Sorry for my bad english.
hi, nice app you have. but i having problem to run the photo frame. [root@FriendlyARM ytl]# ./pf2440 -qws -nomouse ./pf2440: error while loading shared libraries: libQtGui.so.4: cannot open shared object file: No such file or directory any idea?
Solved the libQtGui.so.4 issue, but now come with new eror [root@FriendlyARM distrib]# ./pf2440 -qws -nomouse Bus error
