Hi all, I put Qt 4.6.2 DLL on http://sourceforge.net/projects/qt4lab/ Together with the DLLs I uploaded a simple test example. If you want to try Qt 4.6.2 on your Mini2440 WinCE 5.0 download the zipped library and the exe files, unzip the libraries on a SD or USB card together with the executable and run it. Soon I will upload some other utility programs for Mini 2440 and I need feedback from Mini 2440 Windows CE users to understand if the libraries and the executable are running without problems. Bye Paolo
Qt 4.6.2 WinCE DLL
Hey, I have allso tried to create a Qt app, but with out sucess, i compiled the libraries and the project for CE 5.0, but when i swant to start any binary, nothing happens! No error messages, and about the dll's you gave the link here, they do not work with a simple Qt helloworld test . Did any one experience any similar problems ? Thanks, b
Hi, just few questions... are the DLL in the same directory of the exe? Which cross compiler did you use to compile the exe? I put a simple exe as example, does it work with your installation? Please let me know to understand the problem bye paolo
Hey, Of course the DLLs are with the exe... Yey, your QtLed example works, but any of my binaries doesn't. To compile it, i used the qmake and then nmake in my project directory to create binary. Should i use something else ? Is there a way to compile it inside the Visual Studio ? Thanks and sorry for my typing, i broke my right arm... b
sorry for your arm, I wish you all the best. Ok, qmake and then nmake is ok. I'm using Visual Studio 2008 Prof (but I think 2005 or 2008 shall work in the same way) If you want to recompile the library you can try this guide http://www.sereno-online.com/uploads/InstallazioneQtVCPPEXP.pdf (sorry, is in Italian, but I'm sure, the important steps can be understood in other languages). Just a final question: did you compile with all the SDK for Wiondows CE man mini 2440 and the environment variables are set? Paolo
Hey, I have set up the enviroment variables and the rest that is needed. so from the CMD is wrote: "setpaths": C:\Qt\4.6.2\examples\qtestlib\tutorial1\QT_GUI1>setcepaths wince50standard-armv4 i-msvc2005 Could not find any installed SDK, aborting! 'tmp_created_script_setup.bat' is not recognized as an internal or external comm and, operable program or batch file. Could Not Find C:\Qt\4.6.2\examples\qtestlib\tutorial1\QT_GUI1\tmp_created_scrip t_setup.bat Standard SDK for arm selected, environment is set up "qmake": C:\Qt\4.6.2\examples\qtestlib\tutorial1\QT_GUI1>qmake QT_GUI1.pro "nmake": C:\Qt\4.6.2\examples\qtestlib\tutorial1\QT_GUI1>nmake Microsoft (R) Program Maintenance Utility Version 9.00.21022.08 Copyright (C) Microsoft Corporation. All rights reserved. "C:\Program Files\Microsoft Visual Studio 9.0\VC\bin\nmake.exe" -f Makef ile.Debug all Microsoft (R) Program Maintenance Utility Version 9.00.21022.08 Copyright (C) Microsoft Corporation. All rights reserved. link /LIBPATH:"c:\Qt\4.6.2\lib" /LIBPATH:"c:\Qt\4.6.2\lib" /NOLOGO /NODE FAULTLIB:OLDNAMES.LIB /DEBUG /SUBSYSTEM:WINDOWSCE,5.00 /MACHINE:THUMB /OUT:debug \QT_GUI1.exe @C:\Users\LowRider\AppData\Local\Temp\nm483.tmp LINK : fatal error LNK1181: cannot open input file 'corelibc.lib' NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio 9.0\VC\bin \link.EXE"' : return code '0x49d' Stop. NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio 9.0\VC\bin \nmake.exe"' : return code '0x2' Stop. So i'm figuring it has to be something about the SDK ? Hopefully i solve the problem. Good day, b
Yes you have to install the WinCE 5.0 standard SDK and the mini 2440 SDK (the latter you find on the download of this site) paolo
Hey, Well i think i messed up something, becouse i allready have everthing installed. Now i'm reinstalling everything and am going to try it out. Good day, b
Hey ho, Yeha, it's working! I recompiled the Qt libraries after i re-installed everything, and created a simple button project in Qt creator and it works; Although the application starts very slowly. So this is it, hopefully i can now create a nice UI on Mini2440. Thanks for help paolo and Good day, b
Hi, Can you please put some source code or manual for using mini2440 bsp in Qt Creator and using serial port in it? how can i use this driver Serial Port ,Led,GPIO in Qt? thanks a lot.
Hi again another problem i have, i get this error Could not find specified SDK: STANDARDSDK_500 i run checkdsk -list and i get this SDKs: Pocket PC 2003 Smart Phone 2003 i run following commands too, but nothing changed in above list: set INCLUDE=C:\Program Files\Microsoft Visual Studio 8\VC\ce\include;C:\Program Files\Windows CE Tools\wce500\mini2440\Include\Armv4i set LIB=C:\Program Files\Microsoft Visual Studio 8\VC\ce\lib\armv4i;C:\Program Files\Windows CE Tools\wce500\mini2440\Lib\ARMV4I set PATH=C:\Program Files\Microsoft Visual Studio 8\VC\ce\bin\x86_arm;%PATH% so i cant download paulo pdf too, what am i doing? i m install mini2440-CE5-Sdk, and download mini2440 BSP but i dont know where i must copy these files? please help thanks a lot.
I think the problem is, that the SDK from friendly arm will not install correctly. With the standard SDK for Windows CE from the microsoft site. It works fine. But don't know if this SDK works with the board... Standard SDK: http://www.microsoft.com/downloads/en/details.aspx?familyid=fa1a3d66-3f6...
Ok these are step by step of compile qt for wince that i do, setup VS2005 setup mini2440-CE5-Sdk add to path c:\Qt\4.6.3\bin configure –platform win32-msvc2005 –xplatform wince50standard-armv4i-msvc2005 setcepaths wince50standard-armv4i-msvc2005 and get error cant find sdk. so i setup windows ce 5 standard Sdk and vs2005 sp1. and i have this error again. so what am i doing?
OK i cant compile Qt4.6.3 anyway so,how can i create program for paulo Library? i want use Qt Creator, thanks a lot.
Dear Paolo, I cannot open the link suggested by "http://www.sereno-online.com/uploads/InstallazioneQtVCPPEXP.pdf" Please help me
Dear asdf I also cannot download Qt 4.6.2 DLL from http://sourceforge.net/projects/qt4lab/
I cannot see any problems here. http://sourceforge.net/projects/qt4lab/files/Qt%20DLL%20for%20Windows%20...
Dear Paolo I also cannot download Qt 4.6.2 DLL from http://sourceforge.net/projects/qt4lab/
